Fog Lights Upgrade - Subaru Outback - Subaru Outback Forums
post #1 of 17 (permalink) Old 11-09-2013, 10:36 AM Thread Starter
Car: 2010 Outback 2.5
Fog Lights Upgrade
Does anyone knows if there are aftermarket Fog Lights for 2010-2012 Outbacks?
What I'm trying to achieve is to replace useless stock fog lights in the bumper. They don't give any light further then 10 meters, so one can use them only on the parking lot where speed is bellow 10 km/h.
I'd like to find a way to replace them with some aftermarket lights. This can be some sort of bigger round lights like PIAA 520 or Hella 500 or similar, but I don't see how those can be fitted without pods to the stock bumper.
Is there any solution out on the market? Did someone tried anything?
AlexJet is offline
post #2 of 17 (permalink) Old 11-09-2013, 10:39 AM
jogosub's Avatar
Car: 2005 3.0 R LLBean 4Dr Wagon - totaled
Put a 100W hyper-yellow Nokya (or other brand) bulb there with heavy duty harness with ceramic socket - problem solved!
Quidquid agis, prudenter agas et respice finem.
jogosub is offline
post #3 of 17 (permalink) Old 11-09-2013, 10:50 AM Thread Starter
1. Where can I find upgraded harness?
2. Would it solve the problem? One of the problems is the light pattern, its just too close to the vehicle. Do the fog lights have adjustment for up/down/side?
AlexJet is offline
post #4 of 17 (permalink) Old 11-09-2013, 11:03 AM
rasterman's Avatar
Car: 2006 Outback XT Limited
Sounds like they are working perfectly, and you are misunderstanding their purpose. The whole point of fog lights is to cast a flat, wide beam on the road right in front of you so you can safely move at low speeds in heavy fog. The idea is that it is better than not moving at all.
It sounds like you want driving lights, which cast a much narrower beam and are typically aimed much further out. I don't know if anyone makes replacements that fit the outback bumper, but there are plenty of choices in generic add-on driving lights, and some are excellent quality.
A bulb swap won't help- the beam shape is determined mostly by the reflector and somewhat by the lens.
Performance Valve Body
rasterman is offline
post #5 of 17 (permalink) Old 11-09-2013, 11:09 AM Thread Starter
I perfectly understand the purpose of the fog lights. But they do not have to light up the road just in front of your bumper. They suppose to give the light out for 100 or something meters.
I also understand that most manufactures playing safe and make things, so they will pass all regulations with a spare margin. None of the cars I owed had good fog lights. Most of them had adjuster to adjust them up/down and sideways. Not sure if Subaru allows it. So far my search didn't bring anything.
Generally speaking I'd love to put bigger lights, kind of like Outback used to have before as they look much better then those tiny spots.
AlexJet is offline
post #6 of 17 (permalink) Old 11-09-2013, 12:02 PM
jogosub's Avatar
1. Depending on your bulb, you can get those on Amazon... like this one:
http://www.amazon.com/iJDMTOY-Ceramic-Harness-Sockets-Headlights/dp/B008DM8MUW/ref=sr_1_2?ie=UTF8&qid=1384012804&sr=8-2&keywords=ceramic+heavy+duty+harness
2. You can adjust fog lights - but - with added wattage, you will not need to do that!
With above modification, you will be happy - trust me! I have done it on all my 4 Subarus so far...
jogosub is offline
post #7 of 17 (permalink) Old 11-09-2013, 01:51 PM Thread Starter
Amazon.com: iJDMTOY 9005 9145 HB3 H10 Heavy Duty Ceramic Wiring Harness Sockets For Headlights or Fog Lights: Automotive
The harness on your link is just a couple centimeters long with ceramic plug. I can see it takes out the heat issue on the plug, but what about wire gauging. Adding 100W bulb would increase the current from 4.5A (per 55W bulb) to 8.3A (per 100W bulb). Original wires are small, I beleive within 20-22ga.
AlexJet is offline
post #8 of 17 (permalink) Old 11-09-2013, 02:25 PM
Car: 2007 2.5i Outback Silver over Gray
Higher wattage bulbs can be a large drain on your wiring and electrical system over time. Just get a decent HID kit (whatever color, i have Yellow 3000K) and install that instead of higher wattage bulbs. HIDS run at a more efficient 35W and are much , MUCH brighter than high wattage bulbs-No harness necessary.
The hardest part of the install is where to plae the ballast, other than that, its plug and play.
blueraj is offline
post #9 of 17 (permalink) Old 11-09-2013, 02:48 PM Thread Starter
Does anyone has pictorial or any instruction for fog light adjustment?
I can't find them anywhere...
AlexJet is offline
post #10 of 17 (permalink) Old 11-09-2013, 03:15 PM
Budaru's Avatar
Car: 2013 Outback 3.6R Ltd- Nav, Eyesight, HK, Graphite Gray Metallic
here are the instructions for a '13 OB, which may be helpful
Budaru
Curt hitch & pwr, puddle lights, SuperTone & Fiamm horns, Gentex mirror, interior LEDs, shock sensor, Illumination Kit, 50% tint front windows, acc outlet in console back, Philips LED DRLs, gate lift handle, rear fog lights, clear bra, rain sensing wipers, sunroof visor, 1 touch turns, FX-R bi-xenon HIDs, chrome exh tips, Escort, black grill, 4500 lm LED hi beams, all LED tail lights, air horn, dash cam, XB LED fogs. Takeda cold air intake
Budaru is offline
