Ratcheting sound from right front - Subaru Outback - Subaru Outback Forums
post #1 of 6 (permalink) Old 12-18-2013, 06:48 AM Thread Starter
Car: 2013 2.5i Outback Limited CVT auto
So first off it does it with the traction control on or off.
I have on several occasions been hearing a ratcheting sound coming from the right front when in snow, mud, or sand while accelerating to get through it.
Anyone else have this happen?
wk4036 is offline
post #2 of 6 (permalink) Old 12-18-2013, 09:42 AM
Car: 2013 Limited 2.5 Hole in roof
Yes. It is your traction control using the ABS system to keep a tire(s) from spinning. If it is doing it with the TC off, it isn't off. Bad Switch?
mikelipke is online now
post #3 of 6 (permalink) Old 12-18-2013, 10:10 AM Thread Starter
Thanks for the reply, will recheck
wk4036 is offline
post #4 of 6 (permalink) Old 12-18-2013, 02:19 PM
Car: 2011 SSM Outback 2.5i Premium
LOL, I got the same from mine with the TC off yesterday. I think I hit the "you may have turned off the TC but you're driving like a real idiot so I'll help you out" limit. It was DEFINITELY harder to get the system to "help" with the TC off but it still did try. Of course, I did this on a road with no other traffic and actually did feel in control despite the computer's thought to the contrary.
hallux is offline
post #5 of 6 (permalink) Old 12-18-2013, 02:39 PM
Traction control is always on - VDC elements get reduced or turned off. Meaning cutting your throttle to prevent excessive wheel spin is reduced when you turn the system off with the switch.
Traction control is wanted at all times given this involves using the brake system to slow spinning tires say for example the right side of the car is in a low spot and sitting on ice left side tires are on solid ground- the TC will brake the right side tires and the mechanical results is more power pushed to the left side tires. The ABS system is used by TC to do this.
VDC or vehicle dynamic control involves more throttle control ie reduction and is intended to do things that help a vehicle at speed - stay right side up, stay pointed in the desired direction etc. The advanced capability of newer VDC systems even help with over steer by putting brake pressure on the inside front tire to help correct over steer when someone plows into a corner going too fast.
VDC turned off allows the car to spin tires more and allows for more power to be sent to spinning tires for things like getting out of a snowed in parking lot, scrambling up a slick driveway or driving in sand or mud all cases where the TC system is still very much needed to help push power to tires that have grip and limit wheel spin on the tires that lack grip.
You guys are mixing two systems and their intended designed function together.
ABS will always work with VDC on or off. TC will always work with VDC on or off.
Some aspects of VDC will still exist even when turned off - for instance the car will not let you just spin tires to the red line with VDC turned off a few auto makers learned that there are plenty of stupid people who will do that to the point that a tire explodes and even catches fire!!!! Mercedes had a woman do that in an R series and turn it into a pretty major well known lawsuit.
subiesailor is offline
post #6 of 6 (permalink) Old 12-19-2013, 04:43 PM
Sandroad's Avatar
Car: 2013 3.6R SAP BBP Outback
I'm about to drive north into a winter storm, so I took the time to look up some VDC info. Here's a video from Subaru that shows the VDC system in operation.
SUBARU | Subaru Technology | Vehicle Dynamics Control System
I've not been able to confirm, with either my owner's manual or from info on official Subaru web sites, that traction control remains on even when the VDC switch is off. I'll go figure that out myself real-world with my '13.
Sandroad is offline
