Bluetooth and Tablet connection - Subaru Outback - Subaru Outback Forums
post #1 of 11 (permalink) Old 02-19-2014, 02:27 PM Thread Starter
Car: 2014 Subaru Outback 2.5i
I have an old flip phone and it connects to my 2014 OB 2.5 (basic model) perfectly via bluetooth. It happens automatically whenever I turn on the ignition.
I also have a tablet (Nexus 7 - 2013 model). I use it for streaming music through bluetooth. The problem is that the tablet does not connect automatically to my Subaru's bluetooth. I have to go into my tablet's settings, choose bluetooth, then select the bluetooth device (I named it Subaru) and connect manually each time I start the ignition.
Why does my phone connect automatically and my tablet doesn't? In my old car, I had installed an Alpine bluetooth module where both my phone and tablet connected automatically with the ignition. Really want to do the same with this car. It's kind of a pain to connect bluetooth manually every time.
And to make matters worse, on most occasions, my tablet's bluetooth won't connect on the first try. I have to try to connect 3-4 times until it actually connects. Once connected, it works fine.
Any help or advice is appreciated!
HamDog is offline
post #2 of 11 (permalink) Old 02-19-2014, 03:27 PM
2014Outback's Avatar
Car: 2016 2.5i Limited, crystal white pearl, dark gray interior. Eyesight, Nav, HK radio
You should have a setting on the tablet to auto connect to available bluetooth, or something similiar. The car may also see a conflict between the phone and tablet, not sure what settings are there as I just use a phone.
2014Outback is offline
post #3 of 11 (permalink) Old 02-19-2014, 03:48 PM Thread Starter
Ya, most people use a single smart phone for both calls and music. I'm the exception. Can't find any auto connect settings for bluetooth on my Nexus tablet. Weird how it connected automatically to my old Alpine.
HamDog is offline
post #4 of 11 (permalink) Old 02-19-2014, 05:18 PM
Doc
Doc's Avatar
Car: 2013 Outback 3.6R Auto with Isight
its the car it connects to the first one on the list all others have to be done manually from my experience
Mods: Airaid dry filter, Wolo air horn 118 Decibels – 530 / 680 Hz painted black, front license plate cover (stealth), anti rattle license plate kit rear, rsb upgrade
Past Cars:
2004 Dodge ram 1500 QC 5.7L Hemi(traded for Subi)(only owner)
2008 Infiniti G37S(lost in the big D still paying for it)
2008 Scion TC
2000 Dodge Intrepid
Saturn SC2
Saturn SL
1987 Dodge Ram 50 (x2)
Doc is offline
post #5 of 11 (permalink) Old 02-19-2014, 05:39 PM
Car: '13 Outback Limited 2.5i, Venetian Red Pearl w/Wheel arch moldings, EyeSight, Nav, Moonroof, Puddle lights, Remote start
I'm not sure about the HU in the base model, but that isn't the case with the Fujitsu Ten/Aha HU in my 2013 Limited. Both the phone and audio device pairing setups are separate, and ever since the first connection (after I checked the "Don't ask again" checkbox) both connect for me automatically on my Samsung Galaxy S4. If I wanted to, I could change the audio device to a different device altogether and have that automatically connect.
bsbd is offline
post #6 of 11 (permalink) Old 02-19-2014, 05:47 PM Thread Starter
Interesting. Any way to view this list and change the order on the car stereo?
But both of those services (phone and audio) are on the same device for you (the Galaxy S4). I have two separate devices, I think that makes a difference.
HamDog is offline
post #7 of 11 (permalink) Old 02-19-2014, 06:51 PM
As I said, they do happen to be on the same device for me, but there are two separate setups in the HU settings menu ("Phone" and "Audio Device") and two separate BT connection requests being initiated from the HU when it boots.
I don't know if the base model HU has separate setups or not, that's why I pointed out how this might not apply in your case.
bsbd is offline
post #8 of 11 (permalink) Old 02-19-2014, 09:35 PM
Car: 2014 Outback 2.5i 6MT Carbide Gray
My base model seems to only support one BT device at a time and I have to use the menu to selet a different device. I don't think it's even a first come, first serve thing. I think it uses the last device it was paired to, unless you change it. I've got a Galaxy S3, which I use most of the time in the car and an iPhone 5 that is a work phone. I can also run audio from the iphone over the USB port rather than bluetooth.
dant98 is offline
post #9 of 11 (permalink) Old 02-19-2014, 10:00 PM Thread Starter
My base model can and does handle two bluetooth devices simultaneously. Both my phone and tablet are connected when I shut off the car, so it can't be that it pairs with the last device since both were in use.
I learned something new today. I can start the connection directly from the car stereo. Before, I was starting the connection from my tablet, which sometimes took several tries. It seem if I start the connection from the car stereo (go into menu settings), it connects on the first try.
But I'd still like it to happen automatically!
HamDog is offline
post #10 of 11 (permalink) Old 02-19-2014, 10:09 PM
Car: 2014 Outback 2.5 Premium
I have a 14 Premium, I set my iPhone 5 up as 'audio device' right from the start and it works for music or phone no problem.
thegweed is offline
