Anyone made any adjustments to either of these trim pots on the Sub amp (HK) under the seat? The factory set for gain "looks" to be set towards the louder setting. The High-cut (crossover frequency?) has no reference point.?
I believe it is only for the sub. I think the others are driven by the head unit. The less rear fader you use the more bass you will hear. From 0 to any plus (front) setting doesn't seem to increase bass any more.OBnube/Seaweed,
Thanks for the info. I was looking at my amp tonight and have two questions:
Do you know if the gain adjustment is for the subwoofer only or across all speakers? I'd like to increase the gain on the sub a bit as I barely hear any output even with the stereo at high volumes..
I have to defer to Seaweed on that one as I haven't adjusted mine yet. One possible caution, I do not know if they can be adjusted past "5o'clock". The factory set for gain is 3o'clock. That doesn't leave much room left to turn.Also, were the knobs hard to turn with a screwdriver? I was able to get a small screwdriver lined up in the notch to make the adjustment, but I could not get it to turn. Since it's plastic I didn't want to put too much pressure on it, but typically these adjust pretty easily on other amps.
Thanks.
