No timing belts in 2011 models? - Subaru Outback - Subaru Outback Forums
post #1 of 22 (permalink) Old 04-28-2011, 12:13 AM Thread Starter
Car: right now I dont have a car just an old pickup truck
Is that true that all 2011 outbacks and foresters come with chain driven camshafts? Does the chain needs servicing/replacing like the old timing belts at about 100K miles?
oarfish is offline
post #2 of 22 (permalink) Old 04-28-2011, 12:21 AM
All chains eventually stretch, all gears eventually wear. When it happens, I have no idea and did not read the manual since I do not plan on owning a car that gets to that mileage.
HIS: 2015 Forester XT Premium ISM
HERS: 2015 Forester XT Premium SWP
dboz is offline
post #3 of 22 (permalink) Old 04-28-2011, 12:28 AM
i dont think any of the outbacks have switched to the new motor, not even the 2012's
they all still have the belts
most chains have no replacement date, as the tensions take out what strech does develope
nikbrewer is offline
post #4 of 22 (permalink) Old 04-28-2011, 12:33 AM
the totally redesigned 2.5 engine is chain driven. I really don't understand this chain vs belt thing people have. Belts you replace at 105K - chains you go in and replace all the worn out bits and generally the chain given any failure at a high mileage point is a failure and will do the engine in chain or belt. No difference
The reason an automaker like Subaru will move to chain is they can make the engine even more compact in size vs using a belt which needs more space to be properly run. The reason an auto maker will use a belt it costs less to do - is less noisy and space is not a big issue.
subiesailor is offline
post #5 of 22 (permalink) Old 04-28-2011, 12:33 AM
All 2.5 engines other than the 2011 Forester have a belt.
3.0 and 3.6 engines have a chain.
AWDFTW is offline
post #6 of 22 (permalink) Old 04-28-2011, 12:51 PM
Car: 2011 Outback 2.5i Prem
outback 2.5i engines have timing belt. 6 cyl outback has chain.
lemob is offline
post #7 of 22 (permalink) Old 04-28-2011, 01:34 PM
Honda has slowly moved their engines over to chains to make the high priced belt changes a thing of the past. At least that is my understanding. But it sounds like that chains are not quite the panacea they appear to be. So is there still a "recommended" time frame for the chain to be inspected and changed out?
2014 Honda Odyssey Touring Elite
2012 Acura TSX SportWagon with Tech
dsc888 is offline
post #8 of 22 (permalink) Old 04-28-2011, 01:41 PM
If you look at how much they are cramming into a transverse mounted engine bay I can promise you the reason Honda is going to chain is for space.
As for when a chain driven engine should have the chain gear replaced? All depends on how well the timing chain and set up is designed. But the reality of it is the chain will in most cases far out last all the parts that hold it in place. If anyone of those parts fail after a decent number of miles it won't matter if the chain is unbroken or not the end result is generally the same.
post #9 of 22 (permalink) Old 04-28-2011, 01:52 PM
As alluded to, the chain is but one part. Peruse the 04/05 Nissan Quest chain-guide discussions.
I’ve only had to replace a timing belt once (at 86K), because I replaced the water pump. And replaced the oil seals too at that time, good or bad – ie: go in once.
Belt/chain, it doesn’t matter. I was inspecting the old T-Belt and the mechanic said it could’ve easily gone another 30K, I sold the car at 94K.
GasGuzz is offline
post #10 of 22 (permalink) Old 04-28-2011, 05:32 PM
Car: 2003 LLBean H6 Outback
Other than the guide problems on the '01 and '02 H6 3.0 engines, has anyone ever had to replace a subaru chain or chain-driven water pump?
Dave
CNY_Dave is offline
