Headliner Removed - Page 2 - Subaru Outback - Subaru Outback Forums
Old 11-25-2012, 03:29 PM   #11 (permalink)
scoobydoo2's Avatar
Originally Posted by mooble View Post
Stop!
Read my post in the other thread about soundproofing. Dynamat or other deadeners will not do what you are asking. It's a waste of your money. It will make the sound of rain falling on your roof really cool, but that's about it.
You've got the right idea. You do want to remove the headliner, but not to install Dynamat. Look for a good acoustic material like Bonded Logic Ultratouch: Bonded Logic - Construction Products - UltraTouch Radiant Barrier This is the same stuff car makers put under your carpets. It's only 1/2" thick and very light. It should easily fit between the roof and headliner.
...okay, I have read their stuff...why is it any better than something like dynamat? They both do the same thing. The only difference is that this stuff is cotton.
scoobydoo2 is offline   Reply With Quote Quick reply to this message
Old 11-25-2012, 10:11 PM   #12 (permalink)
Space Invaders Champion
reddoak's Avatar
Car: 2013 Jeep Wrangler 2dr
Did this in my STI with generic dynamat knock off. The roof has fairly large open areas without support... it absolutely helps to have a vibration damper on these. No need to go nuts, just a strip down each open row did plenty good.
reddoak is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 12:49 AM   #13 (permalink)
No, they don't. Dynamat does not block or absorb sound. It stops panels from resonating and creating their own noise, but it does not block existing noise from entering the car. Cotton batting DOES absorb sound and quite well. That's why you find it under almost any carpeting in your car already.
Ideally you would install both, but for different purposes.
mooble is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 04:30 PM   #14 (permalink)
scoobydoo2's Avatar
That is good to know. I have also heard that in California you can buy house insulation made from cotton/recycled denim etc. Same concept and insulates too.
Old 11-26-2012, 04:39 PM   #15 (permalink)
there are a couple photos of the headliner removed on Outback 2012 interior photo page
chuchu is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 05:33 PM   #16 (permalink)
High end custom audio shops will put dyna mat down then lay the cotton over it as mentioned they serve different purposes etc.
subiesailor is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 06:20 PM   #17 (permalink)
bradze's Avatar
i didn't take any pics when i removed my headliner. i could not remove center dome light. screws were in way too tight. i had to carefully stuff the dynamat in between the few inches the headliner came down and the actual roof. i regret not putting in dynaliner or that cotton stuff, but there will be plenty of room. ill probably end up just putting more on the floor and in the doors. expensive and time consuming, but its nice that inside the car the sound hurts my ears, but outside with all the doors closed the stereo isn't too loud and all the crap isn't rattling like kids who have 15" subs in their rusted out shitbox cars. i also have to go 80mph to get as much wind noise as i used to get at 70mph.
who cares about resale value? this is an outback, not getting something else til at least 200k miles!
i have a few parts that aren't supposed to be there...
tired of a sore elbow from the hard plastic armrest? get a cover here http://www.redlinegoods.com/cgi-bin/...r&id=1&aid=774
bradze is offline   Reply With Quote Quick reply to this message
