Issue playing iPod through USB port - Subaru Outback - Subaru Outback Forums
 1Likes
post #1 of 12 (permalink) Old 01-03-2012, 02:21 PM Thread Starter
Car: 2012 Outback 2.5i Premium
Lately I've been having an issue playing music through the built in USB interface using my iPod. This has been working fine since I bought the car in October, but in the last 2 weeks or so it decided to stop working. Using the bluetooth streaming works fine, but when you plug in the iPod (iPhone 4 w/ IOS5) the screen on the head unit says "ipod" track 1, and the track time is always 0:00. This is on the standard head unit in the 2012 premium. On the iPod, it use to tell me that an accessory was connected, and that you couldn't control the iPod from the touch screen, but now it acts as if nothing is connected. (controls are fully functional on the iPod, and the output is being sent to the dock connector as opposed to the bluetooth stream) I've checked that the iPod is seeing the connection, as the battery does charge when connected. The iPod continues to "play" the track, even though no audio is coming from the speakers (yes the volume is not turned all the way down), and the head unit doesn't seem to think that it's playing anything. None of the head unit controls for track/list/etc... are working.
I have tried resetting the settings on the iPod with no luck (issue is still present). One strange behavior that I did notice before it stopped working all together is when you pressed the track up/down buttons on the steering wheel, the display on the head unit changed to "playlist" and the audio stopped playing. (before it was working properly and changing the track)
Does anybody know of a way to maybe reset the head unit? Seems to me like some kind of firmware issue on the head unit that's persisting when you turn the car off/on.
TED B likes this.
aoteri is offline
post #2 of 12 (permalink) Old 01-05-2012, 03:59 PM
eps105's Avatar
Car: 2014 Forester 2.5i Touring with EyeSight; Venetian Red
Easiest way to reset the head unit that I can think of is to pull your battery terminal for a few minutes. Of course, this will reset your ECU and radio presets, too, but no permanent harm.
Before you do that, though, I suggest you try a different iPod to see if it has the same problem. Then you can easily determine if the problem is with the iPod or the head unit.
If it is the head unit, also consider taking it to the dealer as it is under warranty.
eps105 is offline
post #3 of 12 (permalink) Old 01-25-2012, 11:32 PM Thread Starter
I'm still looking to see if anyone has any more information on this. I tried a couple of things, and I'm still having problems. I tried disconnecting/reconnecting the battery. That didn't make any difference. I tried changing out the cable and iPod. (Tried 2 cables, and 3 ipods). Very occasionally (maybe 1 out of every 50 times) the track can be heard through the USB interface, but the controls (except for track up/down) don't function at all. The rest of the time, the iPods claim that the track is playing through the dock connector, and the track up/down buttons function, but no audio can be heard through the speakers.
I'm starting to think that if nobody has any ideas, it might be time to pay a visit to the dealer.
aoteri is offline
post #4 of 12 (permalink) Old 04-04-2012, 06:00 PM
I HAVE THE SAME ISSUE ON MY '12 Impreza
I have the exact same issue on my Impreza. Please let me know what happened with yours and if and how they fixed it at the dealer or if you or anyone found a way. I have had this car for 2 weeks and everything about it was perfect and now this to put a huge black cloud on the awesomeness that was my brand new car. For a Japanese car company, Subaru has got to be dead last in line for reliable gadgets.
JTimpreza12 is offline
post #5 of 12 (permalink) Old 04-04-2012, 09:43 PM
Thai's Avatar
Car: 2012 Subaru Outback 2.5i Limited
Try a different sync/USB cable?
Thai is offline
post #6 of 12 (permalink) Old 04-05-2012, 12:55 PM
Tried several different cables and several diff phones and ipods with usb and it's still stuck on T-01 0:00 on the screen. It's going to the dealer tomorrow and they'll take a look at it. The car was able to work with this before for weeks so I'm not going to accept that this is just not going to work anymore as an answer from the dealer or SoA.
-Judging from what I've read everywhere else, they will probably replace the head unit because nobody has actually posted anything where they figured out what it was or were able to fix it.
post #7 of 12 (permalink) Old 04-05-2012, 10:17 PM
Twit.'s Avatar
Car: 2011 Subaru Outback
Have you recently updated your iPod? If so , that could be the problem? If not , check for updates on your iPod?
2011 Subaru Outback limited, Graphite Gray
Twit. is offline
post #8 of 12 (permalink) Old 04-06-2012, 12:20 AM
mcbrew's Avatar
Car: 2011 Outback 2.5i Premium, CVT, Steel Silver, all-weather package. Upgrades: Tweeter kit, BlueConnect, media hub, remote start, Curt 2" receiver hitch.
There is a cable that plus into the back of the connector and goes to the radio. I would pop the console cover off and make us that cable is secure. Other than that, it might be a failure of the iPod dock module or something in the head unit itself.
-Jesse
SOLD: 2011 Outback 2.5i Premium, CVT, Steel Silver, AWP. Upgrades: Tweeter kit, BlueConnect, media hub, remote start, Curt 2" receiver hitch, 19mm RSB, coil SumoSprings on rear.
2015 Fiat 500c Abarth cabrio.
2016 Kia Sedona
mcbrew is offline
post #9 of 12 (permalink) Old 04-06-2012, 05:37 PM
Good call
McBrew, That is exactly what it was. At the dealership, they did all the tests I did with many ipods and cables. Then they started checking the cables themselves within the car and where they were harnesed. When they followed the cable from the usb port all the way to the back of the radio they found that the cable was wired improperly and was being pinched by a bracket. They said they re-routed the cable and all ipods and cables then worked. So far so good. I went home listening to the ipod, browsing through tracks and took a few calls on the bluetooth and then it went straight back to the ipod afterwards. Looks like Everything works just fine for now. I wish the folks at the Impreza forum were as responsive as you guys and actually wanted to talk about things wrong with the car as opposed to how fast their WRX STI is and not much more (I mean they are bad @ss cars but we all know that -asked this question 3 times over there and got 0 response).
post #10 of 12 (permalink) Old 03-25-2014, 12:51 PM
Thumbs up Thanks!
I have the exact same problem with my 2013 Outback. Thanks to mcbrew and JTimpreza12 for all the info. Back to the dealer it goes with a printout of this forum, just in case they aren't familiar with the problem.
jarbadgolfer is offline
