Oil Change schedule - Page 3 - Subaru Outback - Subaru Outback Forums
post #21 of 61 (permalink) Old 04-17-2012, 11:19 AM
iainb's Avatar
Car: '15 STi and '13 GTI
I'm not sure on the validity of this, but if you switch to synthetic you are supposed to stay with it for the life of the vehicle.
iainb is offline
post #22 of 61 (permalink) Old 04-17-2012, 11:35 AM
Thai's Avatar
Car: 2012 Subaru Outback 2.5i Limited
I believe so. So, again, not sure why anyone would want to do that, esp. if you're still doing changes at 7500 miles interval. The maintenance cost adds up quickly!
Thai is offline
post #23 of 61 (permalink) Old 04-17-2012, 11:40 AM Thread Starter
Car: Outback 2.5 Ltd Azurite Blue
Subaru's website clearly states conventional oil(NON-SYNTHETIC) and every 7500 miles for 2011-2012 subaru 2.5 models.
However i did do 2 oil changes at 3.5 k intervals as i didn't read the manual or the mysubaru website.
I think i will stick with conventional oil & 7500 mile intervals
Thanks a lot for all of your responses.
serenemind is offline
post #24 of 61 (permalink) Old 04-17-2012, 11:55 AM
I just did the math........Changing the oil and filter every 7500 miles for 100k miles, with synthetic and either OEM or Pure 1 filter, will cost me less than $400. I think I can swing that, over a 4 year period.
If, as I plan to do, I use a 5k interval, it will cost $540. Also within the budget.
4wheeldog is offline
post #25 of 61 (permalink) Old 04-17-2012, 11:56 AM
Beornls's Avatar
Car: 2011 Outback Premium 2.5i CVT
I had a similar experience on my first dealership visit (having bought my '11 OB used with 16k miles).
I inquired about the 15k mile service, which per the manual consists of changing oil and filter, changing engine air filter and cabin air filter, and a visual inspection of some parts and fluid levels, and tire rotation.
The dealer said I needed to spend about $559.00 I think it was to do all the above AND change the CVT fluid, change the transaxle fluids, I think they even had a radiator flush in there too. The service tech actually got upset with me when I stated that per my service manual these were NOT required for my service schedule.
Dealers will always push their "recommended" service schedules, which are usually oil changes every 3,000 miles, just like the quickie oil change places will do, etc. Just be careful and read your manual and make sure you follow the schedule according to your driving habits and you'll be ok.
If you change the oil yourself, or take it to a place besides a dealer, make sure you keep your receipt and document it in your service manual....just in case.
PS: I guess I upset this dealership when I challenged their "recommended" service schedule....when I asked the guy just how much to change the oil and rotate the tires they quoted me $99.00. Went to another Subaru dealer and got a $24.99 oil change and $29.99 tire rotation....which is still high IMO as the GMC place I used to take my truck to would do both for $34.99.....no wonder so many people dislike dealer service departments.
Beornls is offline
post #26 of 61 (permalink) Old 04-17-2012, 12:00 PM
iainb's Avatar
They wanted to change the CVT fluid at 15k miles???
iainb is offline
post #27 of 61 (permalink) Old 04-17-2012, 12:03 PM
Thai's Avatar
All true. But, has the $400-540 dollars help your car anymore than my car? I think that we all can spend that over 4 years IF our car would benefit from doing so. I am still holding out on synthetics. I only use synthetics IF the manufacturer recommends it or my car came with it from factory. (My Prius uses synthetic.)
Thai is offline
post #28 of 61 (permalink) Old 04-17-2012, 12:17 PM
Car: 2011 Outback Premium 6MT
Our 2011 Owner's manual recommends synthetic.
RobMunach is offline
post #29 of 61 (permalink) Old 04-17-2012, 12:28 PM
Beornls's Avatar
Yep...they sure did. I thought they were nuts to be honest... I don't even think a CVT fluid change is on the manual service schedule before 100k miles??
What makes me mad is this.... We are on this forum because we are car junkies to an extent, we love our cars and know what to do to take care of them. Think about the average soccer mom or something that walks into a dealership, unaware of what is going on? I wonder how many times a day people are paying for these unnecessary 'services' just so the dealer can turn a profit.
Case in point.... Granted this wasn't a dealership but a prime example of what can go wrong. Sometime last year we took my wifes Nissan Murano into a quickie oil change place, her Murano has the CVT transmission. Well, sure enough, here comes one of the oil change guys with some of the CVT transmission fluid smeared on a card next to some regular type III Mercon fluid. He pointed out how our fluid looks so 'dirty' and needed to be changed for XX dollars more. I shudder to think what would have happened if they put that Mercon in there, which is what WOULD have happened if my wife had been there by herself! Granted I don't know all the differences between the reg ATF fluid and the CVT fluid, but if that tranny had went out, I guarantee you Nissan wouldn't have honored the warranty on it because of the situation.
Beornls is offline
post #30 of 61 (permalink) Old 04-17-2012, 12:58 PM
If you trade your cars in, then it may not be worth it. I keep mine forever, and put a ton of miles on them. (My 4runner has 235+k on it, and nothing leaks, has never used any measurable oil between changes......And no engine maintenance other than belts/plugs/plug wires and oil changes). If it started using oil, I might consider switching to dino.
The first car I used synthetics in was an '83 Honda Civic 1300FE. It got 48 mpg with synthetic, 46 with dino. (I tried to blind the experiment by having my wife use the car, while I was the one changing the oil). The math had me at least breaking even, with the fuel savings. Whether that is still true today, I can't tell you, because I am not going back to using dino to do the test again.
I really am a cheap bastid.......But a really cheap bastid knows that sometimes you need to spend a little to save a little more. Again, YMMV.
