iPhone/bluetooth/USB issue... - Subaru Outback - Subaru Outback Forums
post #1 of 16 (permalink) Old 06-15-2012, 04:41 PM Thread Starter
sbpark's Avatar
Car: 2017 Outback 2.5i Limited, EyeSight & Nav.
2012 OB Premium CVT...I set up the Bluetooth with my iPhone 4S so I can make and receive calls. It's also nice because I use an app called Waze with is a nice (and free) GPS app that so far works really well. It's also great to be able to listen to my iTunes as well.
So the problem is I use the USB connection for my music. WHen I get in the car it works since for maybe 30 seconds to a minute, then I hear nothing (this is with USB selected as the input source). then if I switch the input source on the console to BT-A (bluetooth) I can hear the music, but the controls on the console no longer work to navigate through my iTunes on the phone and I have to actually use the phone to navigate through iTunes. However, the next and previous button on the steering wheel still does work, but I have no way of chugging artist, playlist, etc. from the console if the music is being streamed through via bluetooth.
It seems like once the phone is sync'd via bluetooth it's sync'd for every operation (music, calls, GPS voice directions, etc.) and also inhibits the USB port because when the phone connects via bluetooth, it won't stream anything through the USB.
I know it sounds confusing, just wondering if anyone else has had this problem? The only solution I have come up with is to just mount the iPhone on the dash somewhere with an aftermarket mount which makes it super easy to navigate through iTunes from the phone because it would be right in front of me.
sbpark is offline
post #2 of 16 (permalink) Old 06-15-2012, 06:52 PM
Car: 2012 2.5i Premium 6MT
I have had a similar problem with connecting my iPhone 4 over USB. Basically, if I start the car while the phone is connected via USB, it will play for a few seconds, and then I lose audio (although the head unit still shows the track as playing.) The only solution I have found is to unplug the USB cable from the phone, then plug it back in - that fixes it every time. (Or, more broadly speaking, start the car and let the stereo boot up fully before making the USB connection.)
Not sure if this is something that could be fixed by the dealer or if it's an inherent flaw in the head unit. Next time I'm at the dealership for something else I'll mention it to them.
So just being synced to Bluetooth doesn't necessarily invalidate the USB connection - I have been able to cycle through them and have them both work. I prefer USB since, as you have discovered, the Bluetooth connection doesn't allow you to navigate playlists from either the steering wheel or the head unit controls. I also think the USB connection sounds better - although with the factory system, it's a minimal difference. I expect that once I upgrade the stereo I'll hear more of a difference between USB and Bluetooth.
- sounddevisor
sounddevisor is offline
post #3 of 16 (permalink) Old 06-15-2012, 08:12 PM Thread Starter
sbpark's Avatar
What I resorted to was a vent-mounted holder for the phone, synch'd with bluetooth, and just use the phone's screen to change playlists, etc., and use the steering wheel controls to go forward and back with songs. seems fine, and the sound difference between the bluetooth signal and USB signal is negligible with the stock sound system.
sbpark is offline
post #4 of 16 (permalink) Old 06-16-2012, 03:30 AM
That's exactly what I'm trying to achieve. I have a LOT of music on my phone and using the console dials to look for what I want is actually not very fast... So I prefer the bluetooth streaming. My question would be, which vent-mount have you picked? Is it really sturdy? I just bought USA Gear Vent mount http://www.amazon.com/gp/product/B007TMO3SM/ref=oh_details_o00_s00_i00
I received it today and just installed. Haven't driven with it yet but does not seem to hold to the vent very firmly...
FrenchKheldar is offline
post #5 of 16 (permalink) Old 06-16-2012, 09:45 AM Thread Starter
sbpark's Avatar
Originally Posted by FrenchKheldar View Post
That's exactly what I'm trying to achieve. I have a LOT of music on my phone and using the console dials to look for what I want is actually not very fast... So I prefer the bluetooth streaming. My question would be, which vent-mount have you picked? Is it really sturdy? I just bought USA Gear Vent mount Amazon.com: USA Gear Universal Car Air / AC Vent Mount XL with Adjustable Cradle for Samsung , HTC , Motorola , iPhone and More Smartphones: MP3 Players & Accessories
I just have some piece of crap, cheap no-name mount i got off amazon a few months ago when i got the car and forgot i had it. had an android phone at the time and never ended up using it. Dug it out the other day and it seems to work pretty well, and depending if i continue to like it i will get something a little better. I have my iPhone 4s in a Lifeproof case, so I had to take the Dremel to the holder in order for it to fit properly.
sbpark is offline
post #6 of 16 (permalink) Old 06-18-2012, 11:31 AM
Car: 2012 Outback 2.5i Premium
The reason this happens is not the Head Unit, but the iPhone. The bluetooth syncs a few seconds after the USB connection is made, and on the iPhone, when it detects a new output mode, it auto-switches to the last one made. Like the previous posters said, the only real solution to this (other than disabling bluetooth all together) would be to plug in the USB after the bluetooth syncs.
aoteri is offline
post #7 of 16 (permalink) Old 06-18-2012, 11:37 AM
iainb's Avatar
Car: '15 STi and '13 GTI
You don't need to unplug/replug the phone into the USB.
Select your Music icon and the screen will show that it's connected. On the bottom of the screen is an arrow in a box. Press that and you will get a selector for "Car Multimedia" or "Dock Connector"
Car Multimedia = Bluetooth
Dock Connector = USB
After you switch it to Dock Connector you will have to just forward or back a track and music will resume.
As has been mentioned, it's a problem with the Bluetooth pairing after the USB is recognized and the BT takes over.
With the phone set to Dock Connector the BT phone functions still work, it's just using the USB port for music.
iainb is offline
post #8 of 16 (permalink) Old 06-18-2012, 02:46 PM
JAvendan's Avatar
i typically stream everything through blutooth.
here's my setup and i also have a lifeproof case (and it does work under water!).
http://www.amazon.com/gp/product/B003U8GWX8/ref=oh_details_o01_s00_i00
http://www.amazon.com/gp/product/B003TYFNV0/ref=oh_details_o04_s00_i00
JAvendan is offline
post #9 of 16 (permalink) Old 06-18-2012, 03:51 PM Thread Starter
sbpark's Avatar
sbpark is offline
post #10 of 16 (permalink) Old 06-18-2012, 10:57 PM
skeetjunkie's Avatar
Car: 2012 Outback 3.6R
When I paired my iPhone with the OB via Bluetooth, there was an option to pair only the phone and not the audio. This connection allows me to utilize all phone functions via the steering wheel voice command system. If I connect the iPhone via the USB port in the arm rest storage compartment, I have full music control function through the stereo system interface - playlists et al for iTunes library, and can also play any audio app - all with no BT interruption.
skeetjunkie is offline
