2013 CVT Problem? - Page 2 - Subaru Outback - Subaru Outback Forums
Old 11-16-2012, 08:08 AM   #11 (permalink)
Car: 2011 Outback Premium 6MT
Originally Posted by mccullpl View Post
In my case, there doesn't seem to be any rhyme or reason for the 'abnormal' mode of operation. On a cold start, the tranny always operates 'normally' for at least a mile. Most of the time, it continues to operate normally. Sometimes it doesn't. I don't think the engine load or throttle position have anything to do with it, as the tranny can operate in either mode on exactly the same piece of road, and under the exact same conditions. And when i say it freely spins up to ~2000 RPM, it's like it is in neutral. That freely. I realize the tranny changes ratios as needed, but not this quickly. It really seems like the converter comes unlocked....at least that's my theory. If it truly is operating normally, I would like to understand the reasoning, and under what conditions it changes 'modes'.
The converter cannot make it feel like it is in neutral. It must be another part of the CVT.
RobMunach is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 08:34 AM   #12 (permalink)
So the tranny is linked to the heater control? that is bizarre...I'll have to check it out. I know I've driven with the heat on, and had it acting normally though...
RobMunach, if you've ever driven an old automatic transmission musclecar with a high stall torque converter, that's where my comparison is coming from. I'm not saying for sure that that is what is happening, but it seems to free rev up to 2000-2200 RPM, and then start transferring power.
If nothing else, at least I don't feel so alone anymore, lol
mccullpl is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 10:22 AM   #13 (permalink)
Originally Posted by foxrider68 View Post
Just how the heck did you figure that out?! I tried it on my way home and SOB it worked. Not only did it work but once I turned the heater back on I swear the CVT worked better. However today was about 15 degrees warmer than the last few days but I'm going to do more testing once the temps go back below 30. This is the crazy crap that keeps me on the forum!
Sure enough it worked this morning but when I turned the heat back on the RPM's went up. I believe its to try and warm the car up quicker. So you have two options to avoid it, turn the heat off, or switch to manual. I can bump it up to 5th in manual mode at 35-40 to get the same effect if I want.
foxrider68 is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 10:43 AM   #14 (permalink)
Car: 2013 Limited 2.5 Hole in roof
You know, I wonder if that is the case with the AC as well. Higher engine rpms to keep the compressor working well to cool the cabin. Makes some sense. I know Toyota (not sure about Subaru) has a pressure switch on the power steering hydraulics to sense steering effort, and input from that sensor will increase throttle just a little so that the driver does not sense the engine slowing down, or feel a power loss when turning the wheel at low speed.
It is all magic.
Next thing you know, they will automate the Rendler Spindle.
mikelipke is offline   Reply With Quote Quick reply to this message
Old 11-30-2012, 02:35 PM   #15 (permalink)
Car: 2010 Outback Limited 2.5 CVT
My '13 OB Prem CVT does the same thing. I thought the control to the trans. was screwed up (maybe it is) as compared to the '10 cvt that I owned before. When cold (under 5 miles from starting) and even w/ the blue light off, the engine would go up past 2000 or 2200 rpm when it should've been around 1500 - 1800. Pulling the + paddle would up shift it to 5th, but it would jump back to 4th in a second or two. Sure enough, switching the fan motor off made it act normal (will hold a higher "gear"). Also, after about a 5 mi. drive from cold start, the cvt acts normal.
Thanks so much for finding this characteristic w/ the fan motor (I would've never found it). I wonder if there will be a fix or reflash to over ride the fan switch? If not, at least I now know how to make it behave .
The '13 cvt also "downshifts" itself when coasting down a mountain grade, which I really like. Saves me from picking the wrong "gear" in manual.
Dirtyduck is offline   Reply With Quote Quick reply to this message
Old 11-30-2012, 02:42 PM   #16 (permalink)
Old 12-05-2012, 08:55 PM   #17 (permalink)
Default 2013 Outback with same issue
I am glad that I'm not alone with this characteristic on my 2013 Outback. It began at 6k miles when the weather began to get cool (below 50deg for my car). It takes about 10 minutes of driving for the CVT to get back to "normal" shifting. While I appreciate wanting the car to warm more quickly, it is annoying to listen to the engine at 2000rpm while I'm cruising along at 25mph. I didn't notice this trait in the 2012 Outback I rented for two weeks last winter. Going to ask the dealer if this can possibly be programmed out.
boilermaker1994 is offline   Reply With Quote Quick reply to this message
Old 12-07-2012, 09:31 AM   #18 (permalink)
I've been meaning to get back to this thread...You guys are definitely correct about the the fan switch being tied to the CVT. I found if it isn't fully warmed up, it will go in to the higher RPM mode, until (I assume) it is fully warmed up. I also noticed that if you turn the fan on, and it goes into high RPM mode, you can turn the fan off, and turn it back on, and the CVT won't go back into high RPM mode, but just act normally. I'm assuming the reason behind this is to get the coolant up to temp ASAP, but I still don't like it!
Pat
Old 01-07-2013, 08:28 AM   #19 (permalink)
Default cvt with problem
Hello, I just posted 2 days ago with this same problem, but more so it seems. I have let it idle until the blue indicator light goes off also, but then driven away with the rpm's over 2000 and there is no change until I pop it into manual mode. When I put it back in Auto (engine warm), rpm's go over 2000 again. No rhyme or reason. I have also driven it completely cold after sitting in the driveway overnight at 29 degrees ambient, and had it perform normally until 10 minutes into the drive. I posted 2 days ago under "2013 OB won't change gears" (lack of knowledge of terminology).
mobergj is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 11:44 AM   #20 (permalink)
Kolenka's Avatar
Car: 2013 OB 2.5i + AWP/Moon
Pat
It's not quite about getting the coolant up to temp (although it kinda is too). It's about getting the engine hot enough so that it is safe to bleed heat off of it for the cabin.
It isn't just the fan switch that can cause the RPMs to go up, but the heat you select. While I'm not aware of the A/C upping the revs, I do know that having the heater on will do it. A quick example:
- Turn the heat up to max and start the engine. Revs will be high.
- While revs are high, turn the heat down to cold (or even middle of the range) while leaving the fan on. Revs will drop to cruising levels.
Also note that eventually the heater will turn "fully on" and start blasting air much hotter than when the engine was still cool. This means that the programming has decided it is safe to start bleeding larger amounts of heat from the engine. The revs also drop at this point.
It seems a bit weird, but it does make sense that you don't want to bleed too much heat from the engine while cold, and the revs are higher to heat up the engine faster, and to provide excess heat that the heater can bleed off.
Kolenka is offline   Reply With Quote Quick reply to this message
