6 Speaker Stereo "secret" menu - Subaru Outback - Subaru Outback Forums
post #1 of 56 (permalink) Old 01-02-2013, 03:38 PM Thread Starter
This might be old news, but I wanted to confirm that some of these settings settings seem to work on my 2013 (no nav) 6-speaker stereo :
Hidden menu for 2011+ "premium" head unit? - NASIOC
I managed to change to "Pass through" mode for the flatter eq setting.
SeanU is offline
post #2 of 56 (permalink) Old 01-02-2013, 09:55 PM
seeren's Avatar
Car: 2013, not the one with a V6, the V4 model
Which technique worked for you to get into the menu?
What is the model # printed on the front of your head unit (bottom right)?
I can't get this to work on mine. 2013 #CE617UI.
EDIT: Success. I was trying all the wrong ones. The post #37, which is for a Crosstrek and looks like a different unit entirely, worked.
seeren is offline
post #3 of 56 (permalink) Old 01-03-2013, 07:37 AM Thread Starter
Sorry for the late reply. Same model number.
For the record here are the steps:
1) turn on acc power to car
2) with radio off press the following at the same time
1-2-press tune in - sedan mode
1-3-press tune in - wagon mode
1-4-press tune in - through mode
3) for loudness setting turn stereo on and press 1-6-tune in to switch loudness on or off
Sean
SeanU is offline
post #4 of 56 (permalink) Old 01-03-2013, 12:04 PM Thread Starter
One more thing
I attached the user manual from the FCC site for this head unit. Actual model number is CE617U1 (not an I in the last digit). Unfortunately i don't see any of these service mode codes in the manual.
SeanU is offline
post #5 of 56 (permalink) Old 01-03-2013, 01:24 PM
AO River's Avatar
Very cool find..I love little things like this. What's the sound difference between Sedan, Wagon and Through Mode? What does the Loudness Setting On/Off do?
R o b _D.
Current car: 2013 TB/BC Subaru Outback, 2.5i Premium 6mt
Before you start a new thread, please search first! Learn how
AO River is offline
post #6 of 56 (permalink) Old 01-03-2013, 01:31 PM
Sequoia225's Avatar
Car: 2003 Outback Lim 5spdMT 2.5L, 241K..2013 Outback Lim SAP
does this only work on the premium model?
Loudness setting in short - is what you should turn it to (if you find you prefer it) when you are playing the unit at low levels. Due to physics and the way our ears are designed, if you listen to stereos at low levels, the low end tends to drop away un-proportionality (is that a word?) .
So the loudness setting is an eq curve that compensates for this to make the audio sound more natural. It is only meant to be used at very low levels - at normal levels, it will make the audio sound too "boomy". Whether you like "boomy" or not, this setting was meant to be used when you have the volume lower.
I have found I like this setting esp in a car because of the other noises (road/engine) that also are masking the sound when its low, it doesnt really make it louder - but it makes it a bit more full and clear.
Sorry Sean but can you explain the steps? I am not sure what you mean by the description - sorry if this is obvious to everyone else.
Sequoia225 is offline
post #7 of 56 (permalink) Old 01-03-2013, 01:36 PM
AO River's Avatar
Sequoia - thanks for the explanation.
To clarify then..I currently have the bass level at -2 and it still sounds "boomy" to me, but I imagine I have the loundess setting "On" since I haven't changed it otherwise. If I turn the loudness setting "Off", and listen to audio at normal levels it should make it less "boomy" - correct?
R o b _D.
AO River is offline
post #8 of 56 (permalink) Old 01-03-2013, 02:14 PM Thread Starter
If you look at page 4 in the thread linked in the original post, someone posted graphs of the audio analysis of the different settings. Basically they are eq settings, and "through" mode is a flat signal with no eq applied.
SeanU is offline
post #9 of 56 (permalink) Old 01-03-2013, 02:17 PM Thread Starter
As an example :
Press the preset 1, preset 2 and press the tune dial in all at the same time to switch to sedan mode. Radio should be off but accessory power on to the car.
SeanU is offline
post #10 of 56 (permalink) Old 01-03-2013, 02:19 PM
Sequoia225's Avatar
Assuming its already ON - then yes definitely.
If you happen to read my other thread today - I just got a 2013 Limited and its WAY too boomy in strange ways. I am starting to wonder if this setting is set to on - but I dont know how to access it. I am afraid its not as easy as that its just set wrong - but would love to find out thats the case.
But yes - the loudness setting should NOT sound good at normal volumes. There are WAY better ways to bring up low end at normal volumes. Loudness is only designed for low volumes and will sound very boomy at normal volumes if its on.
