New Horns Installed - Page 2 - Subaru Outback - Subaru Outback Forums
Old 02-26-2013, 03:06 PM   #11 (permalink)
JCBERB's Avatar
Car: '13 OB, Black, SAP
I upgraded my '13 OB horns to a pair of HI/LOW PIAA 85112; they sound great, much louder and deeper than the stock equipment.
And yes the louder the better (within reason of course). The horns have served their purpose when someone is turning into me, did not see me, which tends to happen a lot here in the New Orleans area.
Can the stock horns perform the same function...of course, but the PIAA seem to project a louder stronger sound that quickly gets the attention.
I never lay on the horn when someone cuts me off because it serves no purpose [IMO]; the wife does, and more often than not she gets the middle finger, and it just enfuriates her further more.
Originally Posted by vr4Legacy View Post
I never quite understood why people are upgrading their horns. In my experience the idiot you're honking at doesn't care or is oblivious to the fact that you are honking.
What purpose does this serve? I'm not trying to put down the upgrade, just trying to understand the reasoning behind it.
Primitive Racing front/rear skid plate, King rear springs, 19mm RSB, Venture shield paint protection film, Chrome turn signal bulbs, Weather tech digital fit liners, seat back protectors, HID headlamps, Hella FF55 driving lights, XPel headlight protection film, smoke Headlight Armor taillight film, hood deflector.
JCBERB is offline   Reply With Quote Quick reply to this message
Old 02-26-2013, 03:17 PM   #12 (permalink)
mws4ua's Avatar
Car: 2011 OB 2.5i limited
My wife is occasionally a 'ride the horn' person, too, and she usually gets the same results as yours. I keep my mouth shut most of the time (b/c happy wife.....), but I've never seen the point of it. My horn is generally used for quick bursts.
I am mws4ua and I approved this message.
2011 Subaru Outback 2.5i Limited
2013 Honda Pilot EX-L
mws4ua is offline   Reply With Quote Quick reply to this message
Old 02-26-2013, 03:23 PM   #13 (permalink)
mws4ua's Avatar
Originally Posted by hoppyjr View Post
Thanks - sorry if I'm being dense, but I did installed the Hella Supertones as you did, in the grill with the Subimods bracket, relay, and harness. I'm running the stock horn in the fenderwell/behind the headlight too.
Am I mistaken, or doesn't the stock horn have a power and ground wire within that plug? or is is just a power wire and ground is to the chassis?
Thanks again -
Hoppy
It appears that the plug is just a power plug... There's a single male blade connector in it.
The FIAMMs have two blades on the back of them, but come with a short grounding wire that you use to connect one of them to the bracket that holds the horn in place.
Old 02-26-2013, 04:44 PM   #14 (permalink)
Car: 2011 Outback 2.5i Premium CVT
Perfect, thanks. I didn't recall what it looked like
hoppyjr is offline   Reply With Quote Quick reply to this message
Old 02-26-2013, 05:17 PM   #15 (permalink)
Budaru's Avatar
Car: 2013 Outback 3.6R Ltd- Nav, Eyesight, HK, Graphite Gray Metallic
I replaced the stock horns on my '13 OB with Fiamms a couple months ago, and it was as easy as everyone said. The only "problem" I had was the connectors. Although the stock connectors fit the Fiamms, it didn't seem like a very tight connection. On the stock horns, the connectors distinctly snapped into place, but not on the Fiamms. I am watching them closely to see if the connectors vibrate off at some point.
Budaru
Curt hitch & pwr, puddle lights, Hella SuperTone & Fiamm horns, ProClip iPhone holder, interior LEDs, shock sensor, 19mm RSB, Illumination Kit, 50% tint front windows, hot-wired 2 acc outlets, Nokya Hyper-yellow fogs, Philips 8 LED DRLs, gate lift handle, rear fog lights, Konig wheels, clear bra, rain sensing wipers, sunroof visor, 1 touch turns, FX-R bi-xenon HIDs, chrome exh tips, blind spot sensors, Escort, black grill, LED hi beams, all LED tail lights, air horn
Budaru is offline   Reply With Quote Quick reply to this message
Old 02-26-2013, 05:25 PM   #16 (permalink)
mws4ua's Avatar
You're right about the connection... The blade slid right in, but is only held by friction.
Try a tube of
this stuff this stuff
... Somebody on here recommended it for the connections on my Supertones that kept coming apart. I put enough on the connection w/ the FIAMM that I think it'll hold it just fine.
Old 02-26-2013, 06:36 PM   #17 (permalink)
Car: 2013 Outback 2.5 Premium
I'd like to have my horn somewhat louder both for honking and for making the "alarm system" with shock sensor a more forboding - but not looking for a Hella at 116db. I want to be able to give a quick beep to a pedestrian or cyclist without shocking them into an inappropriate reaction. I know what it feels like to be on that side of things.
Anyone have a good horn upgrade to recommend that might suit me?
Thanks, Jeff
J Delman is offline   Reply With Quote Quick reply to this message
Old 02-26-2013, 06:45 PM   #18 (permalink)
Budaru's Avatar
Try a tube of this stuff... Somebody on here recommended it for the connections on my Supertones that kept coming apart. I put enough on the connection w/ the FIAMM that I think it'll hold it just fine.
Hey thanks! I just ordered the stuff in clear (didn't want my messy work showing so much )
Budaru
Old 02-26-2013, 07:11 PM   #19 (permalink)
Glen1959's Avatar
Car: 2010 Outback Ltd 2.5 CVT PZEV, Azurite Blue Pearl
Default Get out of my way !!
I think I'd use one that sounds like an 18 wheeler for the highway, and put the stock on a separate switch just to say Hi or warn a pedestrian. I need to find a good one that runs on electric and not air.
My first car was a Subaru a 1973 DL that was back in 1976
After many other car I'm Back in a Subaru again!! 2010 Outback 2.5 Ltd WoW how things have changed...
Glen1959 is offline   Reply With Quote Quick reply to this message
Old 02-27-2013, 09:41 AM   #20 (permalink)
I actually used my horn this morning... Some moron was drifting into my lane. I honked at him and he immediately straightened out.
Sure, it probably would have happened w/ the stock horn, too, but IMO the louder the better.
Aside from that... Some people like to just tinker w/ cars. This is something you can tinker with / personalize at relatively low cost (though the Hella set up from Subimods isn't exactly cheap).
Fair Enough, diffrn't strokes.
Not all mods are necessary.
Honestly, I don't think any mod is "necessary". But I've done plenty too just because I can. I mean, who needs an extra 100 hp? But who doesn't WANT it (just one more of these Amazon.com: Add 10 HP Decal Adds Horsepower Car JDM Funny Vinyl Sticker: Everything Else and I'll be there )
Like I said, not trying to put the mod down, just more trying to understand it. Myself I'd put a dixie horn if I were to put anything
2011 2.5i Outback - CVT - 2" Hidden Hitch - Sunroof - HERS
2006 Forester XS - 5MT - Sunroof - HIS
Subies of Past:
'98 Impreza L Coupe | '05 Impreza RS | '08 Legacy GT
vr4Legacy is offline   Reply With Quote Quick reply to this message
