Sway bar Mod picture tutorial - Page 79 - Subaru Outback - Subaru Outback Forums
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Old 11-18-2012, 10:56 PM   #781 (permalink)
Does anyone have the pics of the steps of the mod? They aren't showing up for me. Thanks
Last edited by Mpgillespie; 11-18-2012 at 10:58 PM. Reason: thought i was sending a private message
Mpgillespie is offline   Reply With Quote
Old 11-19-2012, 10:04 AM   #782 (permalink)
jogosub's Avatar
Default RSB swap
see below
Old 11-19-2012, 10:07 AM   #783 (permalink)
jogosub's Avatar
Default Rsb
I just put the 19mm in the back over the weekend - but - unlike others, I have followed Subaru's instructions posted earlier; i.e. removed old 16mm RSB with links attached and only then, switched old links to the new sway bar. In my opinion, it's easier to remove the bottom links from the frame than fiddling around with the top of those links possibly needing the allen wrench to prevent bolt sliding/turning.
Also, I suggest to raise the car on wheel ramps for an easier access. I also suggest spraying the bolts and nuts with penetrating oil the night before the installation.
Old 11-19-2012, 11:48 AM   #784 (permalink)
OBnube's Avatar
I have done that install/removal three times. Twice on a new car and one on a 20 month old.(two winters) I did it without removing the end links from the frame. I thought it was a lot easier(less work) than removing the end links from the car and then from the RSB. Never needed an allen wrench. Tomatoe--Tow-mah-toe. YMMV.
Old 11-19-2012, 11:53 AM   #785 (permalink)
jogosub's Avatar
Good for you - glad it worked for you that way. I did it the "other" way and it was easier for me to do it that way...LOL
Old 11-19-2012, 12:05 PM   #786 (permalink)
OBnube's Avatar
I have to be honest. I never even thought about removeing the end link bottom bolts until you posted the PDF file. Ignorance IS bliss.
Old 11-19-2012, 12:17 PM   #787 (permalink)
jogosub's Avatar
Oh well - the end result is the same.... there might have been some engineering reason why would Subaru do it in a different way than you did it! They also recommend removing the wheel... those union shops must have it an "easy" way so that technicians don't get injured...LOL
Old 11-20-2012, 05:44 PM   #788 (permalink)
Car: Subaru Outback Premium 2012
Originally Posted by Natetheskate View Post
Here is the rework:
1) buy new 19mm bar.
2) look at old bar.
3) take off old bar.
4) install new bar, just like old bar.
5) use blue lock tight, just to be sure.
6) hang old bar from ceiling and do pull ups on it.
you literally could use a one crescent wrench (if your bolts arent rusted) to do this job. no need for lifts. honestly, changing the tire is more difficult.
Also, i always snap pictures before dismantling anything. common sense.
subarubong is offline   Reply With Quote
Old 11-20-2012, 05:52 PM   #789 (permalink)
Just ordered mine. I'm excited.
Old 11-23-2012, 10:01 PM   #790 (permalink)
Originally Posted by Scoobie13 View Post
Everything got installed right but the 19 mm rsb feels kind of squirrel-ly on my 2013. I might remove it to test how it feels with the stock bar back on. Since I installed the strut tower bars at the same time , not sure if that might be causing the vehicle to feel that way at high speeds on freeway.
my stock 2013 does not seem to understeer much at all (off camber entrance ramps and curvy back roads - the front end does not push - if anything, there is almost oversteer - the back wants to break loose first).
I'd be curious about the difference with the stock bar and the strut tower bars though.
walker is offline   Reply With Quote
