#12 (permalink) |
Car: 2010 Outback, 6-speed manual
I'm having the same problem here with my 2010 Outback 2.5. Check Engine light, Traction Control light went solid-on, and emergency brake light and cruise control indicator started flashing. Haven't tried replacing gas cap, but will be taking to dealer soon.
#13 (permalink) |
Car: 2009 2.5i Outback Limited
With all the changes I'm glad I got the 09 Outback.
I got to drive the 2011 with all the bells and whistles. It was cool at first but after an afternoon of driving around and fiddling around with all the toys it fast became apparent that there's just too much going on. And with all the new gadgets there's a huge door open for problems. As for the check engine light, I have heard that a lose gas cap can cause problems and will light up the check engine light. As for all the other lights coming on, that sounds like a more complex problem. I'm sorry your dealer is very un-caring. My old dealer was a bunch of idiots but thank God they sold out and another dealer has taken Subaru over in Lexington, KY. I've owned allot of different cars over my lifetime and I do know that the local dealer determines how people perceive the brand. You should complain to Subaru directly. If enough people complain Subaru will yank their name off the dealer so fast it'll make your head spin because it's their reputation on the line, as well as the dealer. |
#15 (permalink) |
This just happened to me on my way home. After reading this forum I went and checked my gas cap and it has a tear in the rubber seal. I will take to the dealership tomorrow and post the results. Can't believe all of those lights for a gas cap!
#17 (permalink) | |
Car: '13 Outback 3.6R SAP
Nick _________ 2013 Outback 3.6R Limited SAP -- Crystal Black Silica -- Aha SatNav, Remote Start, Tanabe Strut Bar, 19mm RSB, Weathertech Mats, Rear Seatback Protector, Rear Bumper Underguard, STI Exhaust Tips, 3M Clear Bra, Puddle Lights, Hella Supertone Horns Future additions: Interior Illumination Kit, LED's, Yellow DRL's and Fogs Gone: 2012 Outback 3.6R Limited 2009 Ford Flex SEL w/ towing package - PSV (Porsche Support Vehicle) 1982 Porsche 911SC - Track days and Sundays |
#18 (permalink) |
Took it to the dealer today. They replaced the gas cap and reset the codes and problem fixed at no cost and under warranty. The service adviser also said this could happen if you fill up the tank while the engine is running. If the computer runs the check with no fuel cap the same codes will appear.
#19 (permalink) |
...and, despite the fact that my wife, when bringing it to the dealer, told them to just replace the gas cap (and skip the diags) they did the diags anyhow & charged her $118 for it. Argh. But it was the problem. Just a ripped gasket on the gas cap itself. Dealer said it made all of the lights light up, because as soon as the gas recirc breaks due to vapor coming out of the tank, the computer errors, meaning the trac doesn't work, and also cruise won't work. Thus all of the flashy lights.
#20 (permalink) |
Model: 2011/SUBARU/OUTBACK/4DR/ 2.5I Premium (PZEV)
Miles: 9,456 Issue: Started car this morning check engine light was solid, traction control light was on, and brake light was blinking. Location: Fort Bliss, TX Resolution: Called dealership asked if I had just recently put gas in. Advised a few days ago. They asked that I bring it in. It turned out it was a cold start idle issue and that a firmware upgrade was available to correct the problem. Here is the invoice for the work: P050A Cold Start Idle Air Control System A455-288/.04 UPG48 Performed Diagnostics and installed latest re-flash Hope this helps!!!! |
