LinkBack | Thread Tools |
Rating:
#1 (permalink) | ||||||||||
Car: '11 Ruby 2.5 cvt Premium AW/Moonroof
To avoid totally hijacking the Shaker TSB thread, this is about lane wandering with the 2010/11 OB that we started discussing elsewhere.
Discussion so far: Quote:
So one thing I worry a little about is whether the RSB upgrade will have any impact on the dealer's inspection/response to any issues like this. I think the RSB thread mentioned that the techs likely would not notice at all. Anybody come across this?
Am I already hijacking my own thread? |
Car: '08 Veracruz Limited
I hope someone eventually finds out a fix for this problem. On my car it's not an alignment or tire pressure issue. Granted on many days it's just fine, but on some days the car has a mind of its own.
Been bashed for saying it in the past, but my 2001 Wrangler tracked better on the freeway than my OB does. My OB is still better than my old CJ, though ![]() As far as the RSB, I wouldn't worry about it personally. Not to demean the good technicians out there, but most technicians at the dealership probably have a hard time dressing themselves in the morning. Doubt they'll notice a slightly thicker sway bar. |
Car: 2010 Subaru Outback 3.6R Premium
I went with the Rallitek RSB and it seemed to clear up a good bit of the "vagueness" when driving at freeway speeds. The car seems less prone to "wandering" (but I think mine was already less prone to that than some I've heard about on here) and cross winds don't effect it as much as they used to..
When I first got the car, anything over about 70-75, combined with a mild crosswind would send the car in one direction and then the other. My theory was that the crosswind was causing the car to lean, which caused it to push/steer in one direction and when you corrected back, the car leaned the other way, which caused it to seem to steer/push in the opposite direction. It could be quite unnerving, especially at even higher speeds.. I have had one or two instances where crosswinds have still effected the car, but those were predominately strong tail winds that shifted in one way or another.. My Outback seems much more stable with the Rallitek RSB than it was with the stock one. According to Rallitek's website, their RSB "replaces the weak factory 15mm rear sway bar with a RalliTEK 19mm solid. This is a 157% increase in stiffness."
2010 Subaru Outback 3.6R :
LOL.
I’ve seen y-tube’s that caliper-ed the RSB to 16mm, that’s 0.118” delta of 19mm. After it’s all been weathered, yup I doubt the techs will see that. |
Car: 2011 2.5i Premium CVT Azurite Blue Pearl
I changed the RSB to the 19mm Impreza STI spec C and can still feel a gentle tug with strong crosswinds @ 60mph.
I am hoping to get a camping trip under the belt this weekend. I don't really have long highway driving before/after to compare, but should be able to report on the after ![]() The only lane tracking issues I have had so far have been with gusty crosswinds, the they are lessened but not removed with the 19mm RSB. |
#8 (permalink) |
So, i checked my tire pressure-- 32psi all around. I put my rears to 30. I doublt 2 psi will make a difference, but might as well start at specs.
#9 (permalink) |
Car: 2011 Toyota Highlander Limited that replaced an '11 Green OB Limited
Three observations from personal experience.
1) Uneven tire pressure on the fronts make my OB impossible to drive in a straight line - the bigger the difference the more extreme the condition. Now that I'm aware of it I believe (or at least think) I can tell if there's just 1 psi difference. 2) Mine has a tendency to follow the road crown a bit more than any other vehicle I've owned (at least as far a I can remember). In other words in wants to go to the downhill side of the road. 3) The higher the tire pressure the more it wants to 'wander'. It drives best with the fronts at 32 or 33 psi and the rears at 2 psi less than the fronts. As a side note the higher the cross wind the more the impact of 1) and 2).
Dick 'We never really grow up, we just learn how to act in public.' ![]() Want to be happy with your vehicle? Don't read car forums...
#10 (permalink) |
Mine loves to follow any irregularities or grooves in the pavement, too.
I just don't get it. Sometimes my OB can be solid as a rock going down the highway and therefore a great cruiser. Other times it's an absolute handful. Can't tell a consistent temperature, tire pressure, wind speed, etc. that causes it to act one way or the other
