LinkBack | Thread Tools |
Rating:
#21 (permalink) | |
Car: 2013 Outback Limited 2.5 EyeSight & 2010 Legacy Premium
I don't see where the trip computer is factoring in any diffreence. |
#22 (permalink) |
Car: 2011 OB 2.5i Ltd, Graphite Gray
I think we're on the same page. "Trip computer" may not have been the best choice of words. Although they are obviously related, I suppose the trip computer and the MPG display are slightly different things.
Factory Options: Moonroof & Back-up Camera | HK 9-spkr Audio | BSM | All Cargo Nets Upgrades (Self-installed): Kenwood DNX-8120 | Heavy Duty Cargo Basket | 19mm RSB | Hood Protector/Deflector | 110V Power Outlet | Interior Illumination Kit & LED Lighting | Aux USB input | DRL Override Switch |
#23 (permalink) |
I tried the instructions to adjust my MPG for my 2011 Outback, and either I am messing up a step, or does not work for all vehicles ?? All that I got was my Trip Meter back to 0...... Can anyone help me figure out if I am messing up a step or what ?? Thx....
#24 (permalink) |
Car: 2010 3.6R Limited
I had the same issue the first couple of times I tried. When you are going through the lights on/lights off stage, you need press the reset button quickly, don't hold it down at all. Once the LED menu readout between the tach/speedo shows up, you can then hold the button to change options. I found once I was done my mileage from the last time I reset was still there.
Chris |
#25 (permalink) |
Car: 2011 Outback Limited 2.5 Cypress Green
You only have 10 seconds to do the procedure that gets you to the change options. It is very likely to take several tries before you get in. I think it took me at least 3 tries.
#26 (permalink) |
After numerous attempts again, for some reason the electronic brain cooperated and I adjusted my F/E MPG down by -4. Will be a while before I drive enough to fill up again and see if it is closer to reality now, but I do appreciate the info and moral support in trying again. I still have no idea what I did different that it finally cooperated.... I also hope I did not change anything else....
#27 (permalink) |
Car: 2011 Subaru Outback 2.5i Premium PZEV
This is pretty clever...kind of like up up down down left rright left right b a b a sleect start for contra!!! Thanks for the info
