#11 (permalink) | |
Car: 2011 2.5i CVT Man-Wagon
From HERE:
#12 (permalink) | |
What is the material of their spacer? I would assume they also machine their spacers out of aluminum like Subtle, right? Thanks for posting up those pics! |
#13 (permalink) | |
#15 (permalink) | |
#16 (permalink) | |
The Subtle 1" lift kit is 6061 Aluminum and the bolts thread into them. I belive their shim spacers that are 1/4" or 3/8" thick are HDPE. I agree, I think the 1" lift w/o springs would be more than enough. |
#17 (permalink) |
They come with 10.9 steel hardware. The spacers are not threaded, and are HDPE (looked at the website, wasn't sure.)
I'm not too worried about them being plastic rather than aluminum for this use. It's a spacer. More likely than not the spring perches will deform well before these crack. I'm crawling slowly over rough terrain, not going baja blitz at 100 MPH! |
#18 (permalink) | |
So if they are not threaded, how do they secure to the top hat? |
#19 (permalink) |
You will definitely need that 19mm RSB with the ash end of the OB sitting up that high.
Reminds of the mods made to Dodge Caravans when converting them with wheelchair ramps.
'12 Outback Limited 2.5i, Cypress Green Pearl, sunroof, illumination package #2, rear bumper guard, puddle lights, mudflaps, no nav '10 Nissan Frontier SE Crew Cab 4X2 long bed '98 BMW R1100RT-P '86 Chevrolet Monte Carlo SS, restored, original, stock daily driver, '09 Harley Davidson FLHP |
#20 (permalink) |
The spacers are drilled through. They hold a nut in place, and are bolted in place. It's pretty stout.
Cold weather... Not sure, it's a freezing 60 here in Orlando. HDPE if pretty tough stuff, but cold weather wasn't really a concern for me. As far as the rsb goes, I have one out of an 08 STI. I tried disconnecting it to get more articulation from the rear suspension. Curiously enough with the stiffer King spring rates, the swaybar makes no difference in feel. It's been disconnected for about 6 weeks. |
