LinkBack | Thread Tools |
Rating:
#21 (permalink) | |
The lawyers only get involved when you have stupid people playing stupid car stunts. Towing a 4000lb load with a 4000lb passenger vehicle would be a stupid car stunt. |
#22 (permalink) |
Car: 2011 Outback 2.5i Premium, CVT, Steel Silver, all-weather package. Upgrades: Tweeter kit, BlueConnect, media hub, remote start, Curt 2" receiver hitch.
Your opinion.
-Jesse 2011 Outback 2.5i Premium, CVT, Steel Silver, all-weather package. Upgrades: Tweeter kit, BlueConnect, media hub, remote start, Curt 2" receiver hitch, 19mm RSB. |
#23 (permalink) |
Car: OB 2011 3.6R Limited with NAV
Last Fall I drove 2011 OB 3.6R towing 1800 lbs teardrop trailer for 8000 miles.
I was doing fine I but believe it was pretty much close to the reasonable and comfortable maximum. Yes, OB is a serious towing machine but you need take into consideration the speed (steady 60 to 65 MPH ), safe braking distances, reasonable mileage (16 MPG+ but sometimes much better sometimes much worse) and the ability to drive comfortably against strong wind for many hours. In other words towing 1800 lbs trailer seems to be comfortable on long trips most of the time... but sometimes is not ...if it it very windy. Another criterium of comfortable driving (subjective for each driver) is whether you need to think a lot that you are towing the trailer etc... In my opinion anything above 2000 lbs would be problematic in terms of pleasant, worry free towing by Outback on long trips. |
#24 (permalink) | |
Same here I came to that conclusion years ago with my old legacy in 2.5 format. Towed great for 10yrs. My goal for our go anywhere rig was 1300lbs or less which gave me a fair buffer given even at 1600lbs it still tows well. The distances covered, conditions and the climbs etc all play a role in what the car can tow. Moving a heavy load across town 2700lbs no problem. Hauling a bunch of gear 800 miles over a major Pass 1800lbs is stretching it 1500lbs your working it hard and 1300lbs you'll hardly notice. |
#25 (permalink) |
Car: 2013 Subaru Outback Limited 2.5
I do not have 2012 On, but 2001 OB Base Auto. and I have towed U-haul 600-800 lb trailers, 750 miles, with some Smoky mountains roads in the end, loaded with:
-- side by side refrigerator, couple of flat TVs, misc -- rugs, furniture ( smallest coverred trailer, filled to the roof ) -- so many things I cannot even remember now. I belive the 2001 is rated to tow 2000lbs, while 2012 can tow 2700. I think you will be fine. Also, for the sake of saving on weight, you may consider Uhaul "motorcycle" trailer. it has lower sids so it weighs less than comparable size open regular trailer. As far as wiring harness goes, I bought mine at Pep Boys ($40, had to order as they did not have in store). I do not know about 2012, but in my old 2001 it plugs into the harness outlet that is hidden behind the little felt "door" on the right side of cargo area. Then you just run the wire out, shut the hatch and plug it into the trailer connector. Uhaul will help you test the lights. I can only speculate that the new OB will have some similar set up. |
#26 (permalink) | |
The 2010 and newer the trailer wiring plug is behind the driver side rear wheel cover accessed via pulling out the foam inserts and running your finger up under/behind the felt cover over the wheel well in the trunk area. Mine was folded back over its self and taped to its self which made it tough to find and pull loose with two fingers. Then the harness plugs in sits in the spare tire space and gets pulled out and passed under the rear hatch when needed. Works great stays out of the elements when not used and the hatch can be used to pin/hold the wire clear of the hitch gear. I actually prefer this set up over a fixed plug outside the car. I can't tell you how many plugs I've had to replace on my truck due to broken wires and corroded fittings due to being out in the elements. My 2001 subaru went 10yrs with zero wiring issues via the trunk storage approach and it always 100% worked when I needed it. |
#27 (permalink) | |
#28 (permalink) |
Could you post a link? I have only seen US style WD hitches that go in a receiver. Since Euro hitches don't use a receiver, I am interested to see how they work. I have been to Europe, and have seen a lot of people over there towing trailers... But I don't remember seeing any WD hitches over there.
#29 (permalink) | |
Car: 2011 Outback Premium 6MT
FWIW, I hired a guy to do some landscape work. He pulls a double axle dump trailer with a relatively new, 2WD 1/2 ton chevy pickup. The trailer weight 5k empty and he regularly puts about 10k of load in it. The truck has been doing this since new - 115k miles and still has the original drivetrain. He does not even use a weight distributing setup. Fortunately, he has trailer brakes. I think my next truck will be a Chevy. |
#30 (permalink) |
do tow ratings here in the US have to do with stopping distances with a load? my friend thinks that may be it, and i think it makes sense
who cares about resale value? this is an outback, not getting something else til at least 200k miles! come see how i have no life http://www.subaruoutback.org/forums/...-one-mine.html ![]() tired of a sore elbow from the hard plastic armrest? get a cover here http://www.redlinegoods.com/cgi-bin/...r&id=1&aid=774 |
