*OEM Remote Start SOLUTION* for car shutting off when door opened - Page 3 - Subaru Outback - Subaru Outback Forums
Old 11-03-2012, 08:52 PM   #21 (permalink)
JCBERB's Avatar
Car: '13 OB, Black, SAP
Here I go showing my ignorance; so on the 2013 outback with the remote start when activated via remote start and one opens the door to get in the car, the car shuts off....? Im asking to be sure, I have a '13 with SAP and am hoping this issue isnt the case even with the push button start.
That is dumb, I bought my wife a '10 Forester XT Limited and it doesnt do that when remote started...
JCBERB is offline   Reply With Quote
Old 11-03-2012, 08:52 PM   #22 (permalink)
JCBERB's Avatar
Here I go showing my ignorance; so on the 2013 outback with the remote start when activated via remote start and one opens the door to get in the car, the car shuts off....? Im asking to be sure, I have a '13 with SAP and am hoping this issue isnt the case even with the push button start. Im have the remote start on backorder from the dealer.
Old 11-04-2012, 11:20 AM   #23 (permalink)
Car: 2013 Outback 3.6R Limited CGP
Yes, that is correct.
opietrials is offline   Reply With Quote
Old 11-05-2012, 09:40 PM   #24 (permalink)
Car: 2013 Outback 2.5 Touring CVT
Okay, here is going to be 'MY' non-elegant solutions to this problem.
I still have to download the 2013 service manual, but I have the 2009 (so I should get into plenty of trouble...LOL).
I'm electrically (and mechanically savy), so this isn't so far fetched:
Option 1: Put a switch under the dash (or conveniently located) to bypass the driver's door switch until you get in and put the key in the ignition
Option 2: Same as #1, but would be a relay controlled by one of the wires from the OEM remote starter (still have to figure out which)
Option 3: Install my old aftermarket starter from my 2003 Outback. Sure I'll be carrying 2 remotes, but I can use one switch to disable the door switch via one button, and (wiring still to be confirmed): activate the rear window defroster, and possibly augment the climate control 'auto mode' (which seems like a low-level joke)
I could have also add option #4 and leave a old remote starter keypad at work & at home, but I could never get the second remote to work, so I'd lose that ability at work (mornings are more important).
Will keep people advised of my progress.
If anyone wishes to share the 2013 manual wiwing schematics, it would be appreciated. Was going to buy them around Christmas holidays when I'm at work with nothing to do & can download them at my leisure during the 3-day period available/throttled download speed.
edit NOV 7th to add: the 'full auto' climate control system mode that the OEM starter enables actually DOES enable the rear window defroster (and likely the front window defogger & front wiper deicer as well). I only found this out this morning as we had a hard frost & my windows were heated.
So the only thing I would do now is to bypass the door switch. I'm looking through 2009 schematics to see if there is a way to use a relay to take a signal off the window defroster to make this happen. If that circuit is on, then it should be possible.
robertross is offline   Reply With Quote
Old 11-06-2012, 07:13 AM   #25 (permalink)
Car: 2013 3.6R SAP
This reminds me.. I need to send in a complaint on this. It's ridiculously stupid to have the car shut off when opening the door. I'm using remote start because I plan to drive the car. Why would I want it to shut off when I go to get into it? I've never had a remote start shut off when getting in the car before.
kpk02 is offline   Reply With Quote
Old 11-06-2012, 07:37 AM   #26 (permalink)
Where is the best place to send a complaint like this that it will be heard?
Old 11-06-2012, 10:01 AM   #27 (permalink)
SOA
And the reason why it shuts off is that SOA lawyers more than likely said they would be liable for any issue if they didn't do this absolutely stupid thing.
Lets see you have the remote start FOB and FOB to open the door so someone must be trying to steal your car or your 5 year old has the keys and is trying to escape.
fun2drive is offline   Reply With Quote
Old 11-06-2012, 10:58 AM   #28 (permalink)
jogosub's Avatar
Default Auto Shut Off
Fun2Drive:
And that is exactly the reason.... if someone else enters/opens the car (like your 5 year old kid) the kid will not drive off and disappear in the Pacific ocean...smoking and not sharing! LOL
Old 11-06-2012, 07:33 PM   #29 (permalink)
Car: 2012 Impreza Limited Sedan
I've said this before. The implementation on our GM's makes much more sense to me. The vehicle keeps running when I open a door and I have to insert the key and turn it to the ON position before you can shift out of park. Seems just as safe to me.
callmeQ is offline   Reply With Quote
Old 11-07-2012, 12:23 PM   #30 (permalink)
Car: 2013 Outback 2.5 Limited w/ EyeSight
Originally Posted by jogosub View Post
Fun2Drive:
There's an easy programming solution for that which I wish SOA would implement. In addition to my wife's 2013 Outback, I have a Jeep Liberty with an aftermarket Clifford alarm w/ remote start.
If I open the door, it stays running. If the brake pedal is depressed without the key in the ignition then the engine shuts down. You have to press the brake pedal in order to shift it from park to any other gear.
Kriszilla is offline   Reply With Quote
