iPhone IOS6 supports Bluetooth MAP! - Page 3 - Subaru Outback - Subaru Outback Forums
Old 09-24-2012, 07:04 PM   #21 (permalink)
djz
Car: 2013 2.5i Limited w/ EyeSight
Originally Posted by mqnada View Post
Here's what I see. Any idea on how to make the more robust screen show up?
I got this as well on my 4s running iOS6 until I shut down every currently running application on the phone. I think one of the other apps that uses bluetooth was causing it to not work properly. I will check on my way home to see if changing the setting lets me access my incoming messages.
djz is offline   Reply With Quote
Old 09-24-2012, 07:23 PM   #22 (permalink)
Anyone running Verizon and getting this screen?
foxrider68 is offline   Reply With Quote
Old 09-24-2012, 07:31 PM   #23 (permalink)
Car: 2011 Outback Limited 2.5
I have a iPhone 4s running iOS 6 on Verizon. And a 2011 OB Premium w/factory NAV.
My phone shows "CAR MULTIMEDIA" but does not have the "show notifications" "sync contacts" ect. on the screen
I CANNOT sync my contacts
guy66 is offline   Reply With Quote
Old 09-24-2012, 08:54 PM   #24 (permalink)
Car: 2013 2.5i SAP
It took me a couple times to add and delete to get mine working correctly.
I have a 4s iOS6 on VZ
I haven't verified messages but it did sync contacts
tdog4871 is offline   Reply With Quote
Old 09-24-2012, 09:15 PM   #25 (permalink)
Car: 2013 Outback 3.6R Limited Indigo Pearl with Moonroof/Nav/Eyesight
Took me a couple tries as well ... turning bluetooth on and off, restarting the car (more than once) then it seemed to work. I have iOS 6, iPhone 4s, 2013 Outback with Nav. Everything works now except I am unable to send messages ... but it will read them out loud to me.
smessen is offline   Reply With Quote
Old 09-24-2012, 09:32 PM   #26 (permalink)
Car: 2012 Outback 2.5i Premium
I have the 2012 premium (not the nav system) and the new iPhone 5, and I can get the phone to pair, and it will stream music, but the next time I turn the car on, then it won't connect up again. I've totally deleted and re-added the connection on both the phone and the car a couple times with no success. Anyone with the non nav system having luck with the iPhone 5?
nigelvh is offline   Reply With Quote
Old 09-25-2012, 04:21 AM   #27 (permalink)
corvettes's Avatar
Car: '11 OB 2.5i
I have the same problem as nigelvh ^
2013 OB...iphone5.
the 4s had no problem connecting when I started the car..
the 5, I have to go into settings and click on connect.
Is it the phone or the car?
corvettes is offline   Reply With Quote
Old 09-25-2012, 08:15 AM   #28 (permalink)
Car: '13 OB 2.5i Limited
Has anyone had luck with non-nav version?
mqnada is offline   Reply With Quote
Old 09-25-2012, 10:04 AM   #29 (permalink)
Alright, I got mine to work with the non-nav version. The key was to pair with the 'phone' portion of the stereo, before the 'audio' portion.
Before you start, delete any of the previous pairing attempts from the phone, and from the audio portion of the stereo (Available under the menu button).
So what you need to do is hit the talk button on the steering wheel and say menu, then you can use the jog wheel on the right to select options. I deleted the old pairings first, then paired the new phone. After that pairing was done, and I gave it a name, then I went into the audio settings and did a select phone (I think.) Then it worked, and reconnected after restarting the car.
Hopefully this helps!
Old 09-25-2012, 10:16 AM   #30 (permalink)
melloboy's Avatar
Car: 2013 Outback 2.5i Limited w/moonroof package and Illumination Package #2 Dark Grey Metallic
are you able to see texts with the non nav?? how about bluetooth music streaming menus??
melloboy is offline   Reply With Quote
