#21 (permalink) | |
Car: 2012 2.5i Premium CVT
It never ends with technology. It makes me consider getting an Android phone, which will work well with the AppRadio2 - and no proprietary connectors!
#22 (permalink) | |
Car: 2011 2.5 Limited Cypress Green
Yes, I reused my amps and speakers from the stock HK set-up, using the crutch field cables I suggested. |
#23 (permalink) | |
Attached are some photos. I used the standard dash kit from Crutchfield, not the crazy one that requires modification. I have the 8400 head unit, the XM receiver (using stock antenna), bypassed the parking break nonsense with a pep-boys switch, steering wheel control module, Wiring harness with RCA's from Crutchfield, FM Antenna adapter/converter from Crutchfield. And again, you need to run a wire to turn on the factory amps, easy enough to do. |
#24 (permalink) |
Thank you for pics and info!
That screen is HUGE. let's see what Santa brings ![]() Joel Sent from my iPhone using AutoGuide.com App |
#25 (permalink) | |
Good size screen without all the plasticly blue buttons taking up the whole dash that come with the Subaru navi option. I still have my storage bin! |
#26 (permalink) | |
Car: 2010 Outback 2.5 (2013 Legacy front end)
is that as far back as the unit can be installed? OR can it be set back a bit more?
#27 (permalink) |
That is as far as the top of the unit will go back, at least with the mounting kit that I used. The bottom is motorized and will tilt much further back. It works well for me, I noticed that the top corners were slightly out for all of about an hour.
#28 (permalink) | |
#29 (permalink) |
Yeah, thanks. I've seen that. I'm surprised that Pioneer didn't just leave everybody in the dust and move on with new products. Unfortunately for the iPhone 5 you have to buy two other adapters to go with the new cable. That's a lot of adapters! I'll be keeping my system as is for probably another year, then I'll see what's out there.
#30 (permalink) | |
Car: 2013 Outback 2.5i Limited
1. Will this work with the factory bluetooth microphone and steering wheel buttons? 2. Will this work with the factory reverse camera? 3. Does the factory XM antenna require splicing? 4. How much is it extra for the GPS module? I am seeing it at $300, which seems like quite a bit to me. 5. One more I am seeing a lot of complaints regarding only iPhone support. I am guessing this doesn't support Androids? I have read a few reviews that stated the apps work with Android but most say its for the Apple devices.Thanks! |
