#11 (permalink) |
That is precisely why I stated to run the strap over top the board, with one long edge of the board parallel with, and against the left or right roof rack. Then on the board edge which faces the middle of the crossbar, loop the strap down, under the crossbar, back up and back to the side as in the photo below. You can even wrap it around the crossbar more than once to use up some length of strap - like this:
Atlantic Bodyboard Shop | Free Shipping Low Prices - East Coast NY Bodyboarding You can actually run the strap as well, at the outer-edge, around the crossbars in the same fashion. Of course, any clamps or hooks which may be present on the face of the board only need a rag under them to prevent marring of the wood. If the straps, or whatever, have hooks on the ends, hook the hooks to the side bar openings, or, to the crossbars and/or hook to the long-edge of the board using a handkerchief, a clean rag, several sheets of paper-towel folded up, etc. which would prevent any damage to the board's edges. |
#12 (permalink) | |
#14 (permalink) | |
#15 (permalink) |
Car: 2011 Outback 2.5i Base, Cypress Green
That could certainly be true, but if you're really concerned about it you can just wad up some rags to take up the space between the object and the windshield. If the object is snugly against the windshield it won't have opportunity to build up the momentum to break through the glass and become a projectile. And if you're just talking about a board or length of PVC pipe, it isn't going to have enough weight to break through without first gaining some velocity.
#16 (permalink) | |
I'm considering if it's possible to add some D-ring anchor points to the plastic towers or to the crossbars themselves. I'm worried that I'll drill a hole and end up creating something that rattles, whistles, creaks, kills gas mileage, or isn't strong enough to be useful, though. |
#17 (permalink) | |
When your lashing down to anything it is always best to tie vs hook unless your hooks are captive ie have locking gates on them to keep them hooked. The cross bars on the OB and for that matter any roof rack can simply be tied to - the trick is having your strap or rope tied in such a manner that it grips the cross bar. This means having the strap or rope wrapped around the bar more than just crossing under it. Put a physical wrap around it then a simple Bowline knot this wrap then tightens up around the bar and grips it when you pull it tight and over the item your lashing down. Boats and boards can be crushed easily if you get out of hand cranking down tight on them. Look up "truckers hitch" super simple to use - works with nylon webbing straps and allows you to crank down tight and crush your board or boat if your not paying attention to just how tight your going. How do you keep them from sliding forward or aft? If the shape of the board and your bar spread prevent you from a simple mid board tie at the bars which keep it captive due to its shape narrower on the front end and tail end vs fat on the front end or tail end which makes keeping them captive fore and aft very hard - then you need to create a strap that goes around the board its self then this can be tied off to the straps crossing over the board at the cross bars. Hard to describe without a drawing etc. But think of it as you have two different things to address when you tied down. You need to hold the board too the roof "the cross bar lash down across the board via simply compressing the board to the rack" - then you need the board leashed so it can't slide forward or pending the shape of the board - sliding backwards. Or both. |
#18 (permalink) | |
And, for good measure, I hauled a 10' length of 1.5" PVC pipe on Saturday with a car seat in the backseat of my car and the passenger seat upright. I didn't have anyone else in the car with me, but I just folded down 1/2 of the rear seatback and put the PVC between the two front seats and rested the front of it on a balled up sweatshirt on the dash. I could have easily had 2 people with me in the car if I had taken the car seat out. And while I agree that the roof racks are there for a reason, the difficult associated with properly securing cargo to them, when it is much easier to just toss it inside the car, is the reason that I haul long items inside when they will fit instead of on the roof where they 'belong'. |
#20 (permalink) | |
That is the very reason the securing strap extends both over the board and under the board - and, as SubieSailor stated, two or more wraps around the crossbars will hold the board from sliding left and right pretty sufficiently, unless you happen to start road-racing on your way to where you are going. Then, anything is possible. I would think all the Subaru side rails have openings in them, like my '05 does, however I could be wrong. The only way it wouldn't work (as you stated) would be if the side rails are, in fact completely solid with no openings. With that being said, if the same thing is done - wrapping the webbing or whatever down, under the crossbar then back over the board again, the only way a loop of taut webbing (or whatever) could slide off the crossbars and off the side rail would be ONLY if the crossbar end becomes unfastened! Even then, the larger ends may be just large enough to hold the board on the racks long enough to stop the car and make necessary adjustments! ![]() I have addressed the issues as best as I care to here and now. If the OP wants to continue the "what-ifs" then other members can deal with him/her. As in many things, there is much common sense in play here, and common sense is not so common anymore. |
