#21 (permalink) | |||
(This is why I posted in the Gen 4 sub-forum - I figured people with a Gen 4 would understand the roof rack issue. With a normal car roof rack, the holes in the side rails are more than sufficient to do as you describe. In fact, I never would have posted, as it would have just worked fine without having to think about it.) Random image I hotlinked of a Gen-4 roof rack in the "cross rail" configuration. Note the complete lack of side-rails: ![]() Quote:
A skilled boy scout can surely do a bang-up job with knotting up some rope to get a similar effect, but it's still not easy to match the mechanical advantage of a ratchet without a very complicated rope setup. On my previous vehicle (Jeep Liberty with Thule bars), I routinely dropped a canoe on the roof and threw a pair of ratchet straps over the belly. Didn't even need to tie down bow and stern - the only way that canoe was moving in any direction was if the roof came off. I would not attempt that with the subaru, though, as there's just no way to get the same result without a side-mounting point. When Yakima comes out with a Landing Pad that is 2013 compatible, I'll use the ends of a yakima bar that extend past the mount point and should be able to make that work satisfactorily. |
#22 (permalink) | |
Canoes are easy to tie down on cross bars given their shape. () - widest part in the center ie cross bar area - with taper at both ends this alone makes the hull less prone to sliding fore and aft. The bow and stern tie are there to reduce twisting ie levering of the whole package by wind loads. Tying to a cross bar outside of the mount ie the tie can slip off the end - is easily addressed with a simple check tie to the inner side ie inside of the cross bar bracket. If you run 66 inch bars like I do that is a must given the side to side slip factor must be kept in check by having ties to the inner rack area to hold the load center from slipping side to side. I car top a 12ft 55inch wide 135lb racing sailboat this way works perfectly fine even in high winds on the highway - the hard part is getting it on the rack tying it down is the easy part. |
#23 (permalink) | ||
Ropes are fine for a lot of things, but just like ratchets they rely on the user to not screw things up. I've seen too many people flying down the road with a mattress tied to their roof with a piece of twine tied like a shoelace! Quote:
I just pulled the trigger and purchased a MegaWarrior basket to fix this and other roof rack problems. I'm sure it will decimate my gas mileage, but it seems like it's currently the best available option. The top of the basket will act like a normal-width (48") yakima crossbar, and the basket itself will provide the side rails for lashing things down. Now I just need to grow 6" taller! |
#24 (permalink) | |
I learned how to use the trucker hitch as a kid working on the ranch and hauling loads in the truck. You can use a truckers hitch multiple times on the same piece of rope for more pulling power if needed - though rarely ever have I had to do that. Especially with toys which you can easily crush with one single truckers hitch. Last winter I had to use two for more winch power to hoist a tree limb out of the swollen creek behind our house the limb was laying across the culvert and backing up the water and catching more debri causing the water level to raise about 2ft higher than it normally did during a rain storm. One of my old halyards high tech line - out of the tool shed strung from a near by tree and a couple of truckers hitches and I had the 15ft limb hauled out of the creek in about 10 minutes by my self. We had to cut it up to haul it out too big to carry out. |
#25 (permalink) | |
Car: 2011 Outback 2.5i Base, Cypress Green
#26 (permalink) | |
#27 (permalink) |
I agree the current design doesn't seem to have been designed by anyone who hauls misc stuff.
I wrap the strap around the bar on one side of the board, feed the strap through the hook, then cross over the board and wrap it around the bar on the other side. Take that straight back and repeat. Once you tighten it down the straps lock into a notch on the underside of the bar and hold it side to side. I usually end up running another strap front to back as Cobalt mentioned to keep it secure fore and aft. |
#28 (permalink) | |
#29 (permalink) |
The '13s have eliminated the "notches" on the underside of the crossbars. There used to be short rubber pieces with spaces in between on the previous years. At times they could interfere with accesory clamps on the rails.
I'm not happy....till you're not happy |
#30 (permalink) | |
I haul lots of random stuff on the stock rack no issues and its the same effort when using the Yakima gear. The toughest item I haul are mast sections for my boat "Boom" which are fairly slick and 15ft long. The strap down process involves getting a good grip on the mast section and then getting a good tight lashing to the cross bars. The only way to get a good grip is a full wrap around the mast section and having leverage to pull the strap very tight around the mast section. Then lashing to the cross bars is the easy part. The big test to lashing down this type of item was a back up spinnaker pole lashed to a boom on a race boat. We covered 1900 miles of heavy ocean racing before I had to cut the pole free when we destroyed our first one in a round down about 300 miles from the finish line. Again nylon webbing strapping with wraps around the object then enough purchase to cinch it very tight around the pole - then lashing from there to the object your holding it to. I used trucker hitches with the webbing in that case. The only way for us to free the 14ft long pole was to cut it free. |
