#31 (permalink) | |
Car: 2012 Outback 2.5 i Premium
It takes all of about 15 seconds to brush it off.
2012 Outback 2.5i Premium "Paul Hogan" |
#32 (permalink) |
Start and drive it off easily for the first few miles as mentioned. Yes AWD is needed in Florida because of the soft sand. Clearly whoever posted that doesn't live here. Florida in the summer to put the jetski in and out and use in soft sand and winter up north for snow...
#33 (permalink) | |
So fair guess 99.99% of Full time Florida residents only need a pair of floral shorts - matching shirt and a 2wd car to run over to the bingo hall with. |
#34 (permalink) | |
Car: 2010 Outback 3.6R
I believe it setting off right away, and just going easy on the gas until the blue light is off. You can argue that this is actually better for the car, compared to letting it sit at high-idle, at 1500-2000 rpm. For one thing, the car reaches normal operating temperature faster when it is under a bit of load, versus idling. Not only for warming the oil, but also for getting heat out of the heater. That said, if I still lived in Chicago, and had to keep my car outside, I'd be real tempted to have remote start... |
#35 (permalink) | |
I do brush the snow off. Heavy, wet snow on top of ice takes a lot longer than 15 seconds, in fact it even takes longer than 15 MINUTES! I let the heat of the warming vehicle melt a lot of it which then just slides off, to be tossed aside by my snowblower. What do tractor trailer drivers do with the 18 wheeler box trailers. I have never seen one of those drivers go up a 20' ladder to get the snow and ice off the trailer roofs - HAVE YOU? If they did, you would hear of a lot of them slipping off the roof in the process and perhaps never walking again. That is if they survive the fall. Suppose the entire sheet of ice decides to slide off with the driver standing up there, trying to clear the roof! |
#36 (permalink) | |
I was of course referring to passenger vehicles. There are a lot of lazy folks where I live and I've had large chunks of snow and ice catch wind and fly through the air at unsuspecting drivers. Very scary. I always avoid semi's because you never know what's hiding up top.
