#11 (permalink) |
I followed what another forum member did. I too had a little issue with the bulb bases not fitting tightly. Bending the mounting tabs out some solved that problem but if you are not careful a bulb can fall into the light housing which is not a lot of fun to fish out. Cree technology is great I have a number of flash lights that have Cree. They do get really hot but I don't know if they get hot enough to melt a housing. How many of us have backup lights on for more than 10secs?
#12 (permalink) |
Car: 2012 2.5i Premium CVT
I have those same bulbs purchased from a different store, but same price. The solutions to getting them to fit and work properly have already been posted.
They're pretty bright at night, but in the sun it would be difficult for somebody to know you are about to back up judging by lights alone. The lights look like tiny dots. Since lighting is 50% *to see* and 50% *to be seen*, I pulled them out and went back to stock. I also thought they were too blue. I'm all for LED lighting, but the selection of 921 retrofits is just not great at this time. There are some great 7440/7443 bulbs out there (see v-leds) for our other lights. There are similar 921 bulbs with 3 radially firing LEDs in addition to the projector that look a little more promising, but they're loooong. |
#13 (permalink) |
Car: 2013 Outback 3.6 Limited
Yeah watch-out for the bulb fitting. It is a nightmare to fish-out the bulbs, if they pop-out of the socket. I had to go through hoops, but once you get them to fit, they are insanely bright. I find all that extra light useful for backing up at night.
------------------------ STI 19MM rear sway bar STI flexible front strut tower brace GT Spec rear strut tower brace LED interior & exterior lights Forester stainless exhaust tips Alpine 235BT Dynamat Xtreme Subtle dead pedal Bosch ICON blades |
#14 (permalink) | |
Incandescent bulbs create light by use of a filament. When power is applied, the filament glows, generating heat, in turn, producing light. LEDs are the opposite. LEDs create light though a "cold process", when power is applied to semiconductors (usually gallium, arsenic and phosphorus) they're stimulated by the movement of electrons; thus creating photons, the light that is visibly seen by humans. Therefore, generally speaking, led lights/bulbs do NOT generate heat! |
#15 (permalink) |
Car: 2012 Subaru Outback Premium 2.5
I have LED reverse lights in mine too. I picked them up from superbrightleds.com
$6 for each backup light. However like someone said, I added driving lights as another set of backup lights under the rear bumper. I changed the bulbs the driving lights came with to LED. I think I put this in the driving lights. Its easier for me to see backing up now, I have all tinted windows and couldnt see with out the LEDs. |
#16 (permalink) | |
Car: 2011 OB 3.6R Limited
![]() Historically LED's were low power devices and didn't consume enough power for heat to be a huge issue. As the multi-watt, high power LED's have become common, heat dissipation is a larger issue. The difference between LED's and incandescent lighting is that LED's are more efficient and thus waste less power creating heat at the emitter/bulb, and LED's produce almost no infra-red light, meaning the produced light doesn't heat up the lens the way an incandescent/halogen bulb will. |
#17 (permalink) |
Oh yeah...that would be correct. That is why I deliberately said "generally speaking" ... The heat generated in the heat sink may not melt the socket, in my humble opinion anyway....I have bypassed similar issue (when installing high Wattage bulbs in my Subie) by using a ceramic heavy duty harness/socket that will prevent melting of bulb sockets. I've learned a lesson on my 05 Forester, where I just put 100W bulbs in lo and hi beams ... one socket "melted" and not even blowing the fuse. Ever since, anytime I upgrade bulbs I use heavy duty harness (about 5" long) with ceramic socket. Been there - done it!
#18 (permalink) |
Heavy duty low beam harness adaptor with ceramic socket.
#19 (permalink) | |
Car: 2011 OB 2.5i w/CVT, Steel Silver
