#11 (permalink) | |
Car: '12 Outback 6sp MT
Give more throttle while you release the clutch pedal... Rev the engine at 1,500 rpm when you engage the friction point and it will be fine ! |
#12 (permalink) | |
Also every car built for many years now are designed to return optimum fuel consumption at rpms and vehicle speeds that fit the gearing meaning if your lugging the car or shifting to a larger gear at too slow of a speed your actually not running the car at is most efficient speed or RPM - so people who do this thinking they are saving gas are actually doing the opposite and getting worse mileage than they would get if they were to simply run higher RPMs and not lug gears. |
#13 (permalink) | ||
Car: '11 2.5i 6MT
First, thanks for taking the time to respond. Not meaning to sound like a jerk, but I know how to drive a **** stick. I have driven them exclusively for 20+ years (and 30+ if you count tractors). No more lectures on how to drive, please! Out of every single MT car that I have driven (mine or others) which easily exceeds 25, I have never-ever-ever experienced this kind of powertrain noise from boggy starts. Yes things moan and groan, but do not go "whack-whack-whack". I am not describing a problem with my driving habits, I am explaining the condition that most demonstrates this noise. If it is a common noise, then I won't waste my time fighting the dealer and learn to live with it. If I have it different or louder than others then I want it taken care of, if for nothing else but resale issues. -Rob |
#14 (permalink) | |
#15 (permalink) | |
Car: '11 2.5i 6MT
Probably in a few days. |
#16 (permalink) | |
Car: 2011 Outback Premium 6MT
#18 (permalink) | |
#19 (permalink) | |
I don't have an OB as yet but what you describe sounds a lot like the rattle/clunk a dual-mass flywheel makes. BMW has used these for years and both my cars exhibited some degree of "clunking". Do you hear it at idle with the gearbox in neutral? If you do (and it may be very subtle and not happen always), try pushing the clutch pedal fully down. If the noise goes away, that will confirm it's the flywheel. I looked up the OB factory service manual and while it does not list the flywheel as dual-mass, it is listed as "flexible". I think that's the same thing. The sound you hear is completely normal for a dual-mass. If it gets really loud, it may mean that the springs between the masses are failing. On my 535i (E34), the clunking was so bad at idle that other drivers would start looking around. Changing the gearbox solved the issue since it's a resonance caused by the flywheel and the input shaft of the gearbox. |
#20 (permalink) |
I don't have a 4th generation outback, but I do have a 2011 Legacy GT with a 6mt. No clunking. I've had 8 Subaru's with manual transmissions and the only one that's clunking on start out is my 2003 Outback with 177,000 miles and the problem is a differential mount that needs to be replaced. Keep bugging the dealer, it's not normal.
Present & Past: 2011 Legacy GT 2009 Impreza 2008 2.5I Outback 2003 2.5I Outback 1998 Impreza RS 1996 2.2 Outback 1990 2WD Legacy Wagon 1985 4WD Wagon 1982 4WD Wagon |
