#21 (permalink) | |
Mike F
2004 Subaru Outback Wagon - 122,000 miles, 2.5 H4 EJ251, 4EAT, DD 1999 Pontiac Grand Prix GTP - 190,000 miles, L26/L67 hybrid, 4T65E-HD, lowered, Comp G wheels, SD headers, FWI - Toy/money pit ![]() Love: it's what makes a Subaru, a Subaru |
#22 (permalink) | |
Car: 3.6R Limited with EyeSight and EVERYTHING YOU CAN GET!
...of course, they don't weight that much. |
#23 (permalink) | |
#24 (permalink) | |
I've seen it happen on a Focus. Not exactly a heavy car. In fact on that car the rears were cupped so badly you could tell just by looking at them... from 5 feet away!
Mike F
#25 (permalink) |
Car: 2006 Outback XT Limited
Documentation always seems to be 10x as expensive as production, in any field... the factory manuals for my old carbureted, air cooled VWs were $80 in 1980s money, and those cars were stone age tech compared to the complexity in "average cheap" cars like today's hondas & subarus.
#26 (permalink) | |
--- So I pulled out the various supplements, including the tiny chart maintainance intervals... and then enlarged / merged that with the various places in the owners manual to create a comphrensive one stop location pamflet for the cars. One for the Outback and one for the Legacy. I guess I'll rotate the tires this weekend. -grin- I'm still shocked that given all the stuff the sales team went over, the one thing they didn't stress was that your tires effectively need to be flawlessly close, including wear. Interesting to me: The maint intervals appear to be every 30K miles, and you only replace the oil filter, oil, air filter, and brake fluid. It's sorta odd that everything else, except the spark plugs, is "Inspect." Tires are rotated every 7500 miles with the oil. I wonder if Subaru will freak out if you use DOT4 synthetic brake fluid? (I have like 6 qts of the stuff laying around...) |
#27 (permalink) | ||
I recall that DOT 3 and DOT 4 are fully compatible as they are both glycol-based. It's DOT 5 you don't want to mess with. Assuming that your stockpile is in sealed containers I'd say go for it. If the seal has been broken, atmospheric moisture will get in quickly and then it's no better than what has been in the car all along. |
#28 (permalink) |
someone tell him what happens when you have a sidewall puncture on one tire of a matched set that are all at 40% tread remaining.
go ahead tell him
#30 (permalink) |
Everyone,
No matter if you have an AWD/4WD/FWD/RWD car you are a dumbass if you don't rotate the tires every 10K or so. They will last 60K and you can replace them at the same time because they will be worn out the same. Also if your car starts pulling to one side, check the inflation and if that doesn't fix it you or your spouse probably hit a curb or hit a pothole. Get an alignment to fix it. This is car ownership 101. MW |
