#11 (permalink) |
Car: 2011 2.5i CVT Man-Wagon
If the trailer has axles you can move, you can do that. A U-Haul won't.
If you need more weight on the tongue, move your cargo forward, if you need less, move it back. |
#12 (permalink) |
The 5x10 uhaul is nose heavy to start with! Two couches wont impact the balance enough to be a worry.
Number one warning is Uhaul trailer brakes. Have them do a plug check ie light test before you exit the yard. Tip! take a second person with you who can either do the lights check with the uhaul guy or allow you to do it. Their trailer wiring gets screwed up all the time and mor often than not will blow your fuseon you brake lights. Your shift lock will then prevent you from shifting out of park. Have fuses and if you blow one do not hook up the trailer lights. Get another trailer or run during the day and sstay off tge main drag |
#13 (permalink) |
Just this guy, you know.
Car: 2009 2.5i, H4, Auto.
Since you say that you don't have a brake controller, see if you can rent a trailer that has a self contained brake system, usually a hydraulic cylinder in the hitch assembly. That way you don't need to worry about getting a controller installed just for this one time.
Beyond that, take the drive easy. Keep you acceleration slow and leave plenty of following room between you and the car in front of you. Trailer brakes help, but don't count on them being able to save you. |
#14 (permalink) | |
No brake controller needed for the 5x10 Uhaul they have a basic pressure hitch system self contained to the trailer. My comment above was regarding the brake lights and faulty wiring on the rental trailer. The last three Uhaul trailers I've rented all blew the fuse in two different vehicles being used. For local day time trips and not having any other option I simply left them unplugged. For longer highway trips I had Uhaul track down a trailer that worked or fix their faulty wiring on the trailer they were trying to give me. Couches weigh so little the 5x10 trailer will not be a weight issue for the OB or a brake issue regarding stopping. If its an open trailer your biggest risk is having the cushins blowing out and all over the road like most people I see hauling couches they fail to put the pads some place where they won't exit the vehicle when they are going down the road. |
#15 (permalink) |
^this.
www.backcountryfishingthekeys.com https://www.facebook.com/BackcountryFishingTheKeys Mods; King springs, DDM HID, hood deflector, window vents, 2" Hidden Hitch, transmission oil cooler, seat-covers, Tanabe strut bar, 19 MM RSB, Primitive skid plates, K&N air filter, tinted windows, blacked out foglight surrounds, Wheel arch moldings. |
#16 (permalink) |
Car: 2011 3.6R Limited Moonroof
I just realized that the door opening on the 5 x 10 trailer will make it difficult to get 2 couches into the trailer. Would it be safe to tow a 6 x 12 uHaul trailer with the OB ? the empty trailer weight difference between the 5x10 and 6x12 is 700 lbs (1250 vs 1920)
-V 2011 OB 3.6R Limited Moonroof w/ Backup mirror - hers 2007 BMW 335i 6sp - mine |
#18 (permalink) | |
Car: 2012 Outback 2.5i CVT
#19 (permalink) | |
#20 (permalink) | |
Car: 2010 2.5i Premium - 19mm STI RSB - OEM Hitch
