Took my car into GO Subaru West, Golden CO for the 15K service. They wanted to change ALL the fluids, plus whatever else comes with the 15 K service. Total would have bee about $375.00. I said to just do what the factory recommended. Cost was $200.
GO claimed Colorado driving is "harsh conditions" warranting the extra service. Should I do this? Thanks. |
Car: 2013 Outback Limited 2.5i
Colorado is considered a severe service area mostly because of the dust on the plains and mountain driving elsewhere. For most automakers that involves changing filters (air/cabin) and oil more frequently, plus more frequent brake/transmission service.
Are they advocating changing the brake, radiator and transmission fluid too @ 15K? That seems like additional revenue for your dealer with no benefit to you. The schedule does recommend brake fluid replacement @ 15K under 'hard mountainous driving' which may or may not apply to your specific driving pattern. $200 seems excessive for an oil change, tire rotation, and brake/suspension inspection. I'd expect $100-$125 tops. Maybe they are including the brake fluid replacement in the $200 figure. |
rotate tires
change oil and filter replace AC filter inspect everything $209. That seems really high. I forget the other fluids they wanted to do, but they wanted to replace the differential and brake I guess. This is a new car and the dealer is close to work so very convenient. Seems really high to me. I would change more fluids if it was a good idea. |
Car: 2012 Outback 2.5i Limited, Ruby Red Pearl
Per the My Subaru factory website, our 2012 Limited 2.5i required the following:
Recommended Maintenance 15,000 miles Replace engine oil Replace engine oil filter Inspect disc brake pads and discs, front and rear axle boots and axle shaft joint portions Perform inspect brake lines and check operation of parking and service brake system Inspect clutch operation Inspect steering and suspension Perform rotate and inspect tires Replace a/c filter We also needed the WQC-39 ECM reprogramming recall performed. They could only perform the recall during the week when we needed the car for work. So they gave us a free loaner and the entire service above was only $124.82. Now we do not live in Colorado, but I think it’s time you find another dealer. |
#5 (permalink) | |
Car: 2011 SSM Outback 2.5i Premium
Agreed. That service on my 2011 would cost me $50 WITH SYNTHETIC OIL! EVERY item listed is allegedly done for that $50 except for the clutch operation check and the a/c filter.
Car: 2011 Outback 2.5i Premium CVT PZEV
At 15K I had this done, minus the AC filter and I think I paid about $25!!! Yes, I live in Colorado and had it done at my dealership...
2011 Subaru Outback 2.5i Premium 2006 Harley Davidson Road King Classic 2005 BMW K1200LT |
#8 (permalink) |
Car: 2013 Limited w/EyeSight
Follow the service schedule published by Subaru - really simple and credible defense for anything the dealer says.
Reputation is so important to the car makers that you would not be getting service schedule that would harm it. I did have one car where they changed the service guidelines after I bought it and before out of warranty. That change was still less extreme than what the dealer wanted. No babying and nothing more than suggested maintenance had my last car last and be reliable for 14 years. |
#9 (permalink) |
They are probably charging your $100 for a cabin air filter replacement - like dealers of all makes do. You can change the cabin air filter yourself in 5 min. OEM filters cost about $20. aftermarket ones are $12-$15 (basic/carbon impregnated type)
Here is do it yourself sample video: |
#10 (permalink) |
I figured it was kind of high, to put it mildly. I called the dealer where I bought the car, Flatirons, and they say they do not change all the fluids at 15K, they just do what has been described above as recommended by Subaru. Too bad, GO West is really close to my office.
