2013 rough shifting - Subaru Outback - Subaru Outback Forums
Old 01-16-2013, 03:47 PM   #1 (permalink)
Default 2013 rough shifting
I have a 2013 3.6 and have noticed that recently (cold winter weather) when slowing down and then speeding up like going into a corner and coming our of it or at a red light that just changes the motor revs when I step on the gas, but the transmission seems to be a second late so when it engages the Outback take off faster than I would want. I read in older Outbacks the rough 1 to 2 or 2 to 1 shifts could be remedied by a re flash. Do others experience the same thing in the 2013 and is there an adjustment that would better co ordinate the shift points?
Jocko is offline   Reply With Quote
Old 01-16-2013, 03:57 PM   #2 (permalink)
147_Grain's Avatar
Car: 2013 Outback 3.6L Limited with EyeSight
After experiencing similar symptoms..........
I had the 5-speed automatic in my 2013 Outback reflashed with a transmission learning control procedure (at 207 miles) and also changed the factory (initial fill) transmission fluid with Subaru ATF-HP for much improved results (at 1,950 miles).
147_Grain is offline   Reply With Quote
Old 01-16-2013, 04:02 PM   #3 (permalink)
AO River's Avatar
There is a noticeable lag with the electronic throttle response when first stepping on the gas. Not sure if that can be remedied..
R o b _D.
Current car: 2013 TB/BC Subaru Outback, 2.5i Premium 6mt
Before you start a new thread, please search first! Learn how here.
Buying or just bought a Gen 4 Outback FAQ
AO River is offline   Reply With Quote
Old 01-16-2013, 06:07 PM   #4 (permalink)
Nickshu's Avatar
Car: '13 Outback 3.6R SAP
Not sure if it applies to 2013's but in 2012 Subaru released a Reflash for the 3.6R's 5AT transmission to address this issue. It is called "Shift Shock"...a "clunk" that occurs when accelerating out of a corner or reapplying the gas pedal after coasting. Do a search, there is discussion on it.
I had it done on my 2012 and it completely fixed the issue.
Nick
_________
2013 Outback 3.6R Limited SAP -- Crystal Black Silica -- Aha SatNav, Remote Start, Tanabe Strut Bar, 19mm RSB, Weathertech Mats, Rear Seatback Protector, Rear Bumper Underguard, STI Exhaust Tips, 3M Clear Bra, Puddle Lights, Hella Supertone Horns
Future additions: Interior Illumination Kit, LED's, Yellow DRL's and Fogs
Gone: 2012 Outback 3.6R Limited
2009 Ford Flex SEL w/ towing package - PSV (Porsche Support Vehicle)
1982 Porsche 911SC - Track days and Sundays
Nickshu is offline   Reply With Quote
Old 01-16-2013, 07:34 PM   #5 (permalink)
AO River's Avatar
Try this read: 3.6R tranny question
R o b _D.
