2013 IIHS Small Overlap test - Subaru Outback - Subaru Outback Forums
Old 01-29-2013, 10:55 AM   #1 (permalink)
subyroo651's Avatar
Car: 2013 Outback 2.5Ltd w/EyeSight
Default 2013 IIHS Small Overlap test
Guys, while searching the net I found that Subaru updated its Airbag controller to deploy the Side airbags in the event of this kind of collision. However it was on models built after August 2012.. I took delivery of mine on Sept 1st so I m guessing I wasn't one of the luck ones, do you think this will still be available through TSB or similar?
IIHS Small Overlap Test
subyroo651 is offline   Reply With Quote
Old 01-29-2013, 11:17 AM   #2 (permalink)
Hey Subyroo. You can check the build date on you drivers side door sticker. I emailed Subaru USA, and the response was that there will not be a retrofit on any cars with an 8/12 or earlier build date.
SeanU is offline   Reply With Quote
Old 01-29-2013, 11:38 AM   #3 (permalink)
subyroo651's Avatar
I have the other car today so I can't check it otherwise I would.. But ether way that is a load of Bull if so.. There is no reason why someone who was eager enough to buy that early should be shunned by SOA. I wouldn't by any means accept that as a solution..
Old 01-29-2013, 12:07 PM   #4 (permalink)
If it was just a software upgrade I would agree, but airbag systems are complicated (there are sensors at every bag location) and the main control module may not be rigged to receive updates. I suggest you contact them yourself and see if you can get further than i did.
Old 01-29-2013, 12:18 PM   #5 (permalink)
fatabbot's Avatar
Car: '08 Veracruz Limited
You can't expect manufacturers to retrofit safety equipment every time there's an upgrade or some sort of change. Way too cost prohibitive and even a potential liability should something not work as intended.
Enjoy your Outbacks
Old 01-29-2013, 01:44 PM   #6 (permalink)
subyroo651's Avatar
Indeed, I will see what results. If it is a module that has been Modified/updated then that's one thing. But a software/Firmware update shouldn't be that big of a deal. Guess we'll see.
