Dealers and fumoto valves? - Page 3 - Subaru Outback - Subaru Outback Forums
Old 02-25-2013, 12:15 PM   #21 (permalink)
Originally Posted by mxfrank View Post
I'm using statoseals instead of crush washers. Not only do they seal better, they last through several oil changes (I've had the same one on there through three changes).
I have never replaced the crush washer on my daily drivers ever, they don't really cause many issues.
Old 02-25-2013, 12:51 PM   #22 (permalink)
Car: 2013 Limited 2.5 Hole in roof
Neither have I, and I don't use a torque wrench unless I am putting an engine back together.
mikelipke is offline   Reply With Quote
Old 02-25-2013, 05:01 PM   #23 (permalink)
Originally Posted by OBnube View Post
It's painted over after it's compressed.
My point was that my drain plug was way overtightened from the factory. Paint doesn't require 80+ foot pounds to break loose. Gorilla Magee tightened mine. I had to use a 6 point socket to avoid tearing up the hex on the plug. That does not help the threads in the pan keep from distorting. Just sayin'.
4wheeldog is offline   Reply With Quote
Old 02-25-2013, 05:16 PM   #24 (permalink)
OBnube's Avatar
Originally Posted by 4wheeldog View Post
My point was that my drain plug was way overtightened from the factory. Paint doesn't require 80+ foot pounds to break loose. Gorilla Magee tightened mine......
I agree, I think mine was put on by the Hulk on Monday after Super Bowl. Mine made an audible cracking noise when it finally broke loose, hence the contributing factor comment.
Old 02-25-2013, 07:37 PM   #25 (permalink)
< Incidentally, another argument in favor of Fumoto is thread damage from removal and constant retorquing. Too much twist by an 18 yr old quick lube kid and you can damage the threads.>>
A statoseal is a steel washer with a buna rubber insert. You can find them at McMaster-Carr, search on statoseal. I expect the one will last a couple more oil changes.
I think that the probability of thread damage in a steel pan is less than the probability of having the Fumoto valve ripped out of the bottom by road debris. I do my own changes, wouldn't use a quickie lube for anything.
mxfrank is offline   Reply With Quote
Old 02-25-2013, 07:47 PM   #26 (permalink)
scoobydoo2's Avatar
Originally Posted by JimDod View Post
Just not as nice as "free"
...after the freebees run out, of course. Then you put that fumoto valve to use in your own driveway.
scoobydoo2 is offline   Reply With Quote
