Ordered Items
Parts and Accessories
Description Price Core Qty Total
Mechanical Catalog - 2006 - Subaru - Outback
engine, cylinder head & valves, valve seals Outback/Legacy Intake 3.0L $5.25 $0.00 12 $63.00
engine, cylinder head & valves, valve seals Outback/Legacy Exhaust 3.0L $2.84 $0.00 12 $34.08
Collision Catalog - 2005 - Subaru - Outback
exhaust system, exhaust components, converter & pipe gasket 3.0 LITER, front $11.42 $0.00 2 $22.84
exhaust system, exhaust components, converter & pipe gasket 3.0 LITER, rear $19.97 $0.00 1 $19.97
exhaust system, exhaust components, converter & pipe gasket 3.0 LITER $9.41 $0.00 1 $9.41
cooling system, cooling, radiator & components, upper hose 3.0 LITER Right $13.13 $0.00 1 $13.13
cooling system, cooling, radiator & components, upper hose 3.0 LITER Left $13.13 $0.00 1 $13.13
cooling system, cooling, radiator & components, lower hose 3.0 LITER $14.96 $0.00 1 $14.96
cooling system, cooling, radiator & components, cooler line 3.0 LITER, upper $15.19 $0.00 1 $15.19
cooling system, cooling, radiator & components, cooler line 3.0 LITER, lower $7.33 $0.00 1 $7.33
cooling system, cooling, belts & pulleys, alternator belt 3.0 LITER $29.21 $0.00 1 $29.21
cooling system, cooling, belts & pulleys, idler pulley 3.0 LITER $34.64 $0.00 1 $34.64
cooling system, cooling, belts & pulleys, tensioner 3.0 LITER $79.64 $0.00 1 $79.64
cooling system, cooling, water pump 3.0 LITER $104.96 $0.00 1 $104.96
cooling system, cooling, water pump, water pump seal 3.0 LITER $2.99 $0.00 1 $2.99
cooling system, cooling, water pump, water pump gasket 3.0 LITER $3.13 $0.00 1 $3.13
cooling system, cooling, water pump, thermostat 3.0 LITER $22.46 $0.00 1 $22.46
cooling system, cooling, water pump, return pipe clamp 3.0 LITER $1.82 $0.00 2 $3.64
cooling system, cooling, water pump, connector hose 3.0 LITER $8.68 $0.00 1 $8.68
engine, engine / transaxle, engine parts, valve cover gasket 3.0 LITER, outer Right $14.96 $0.00 1 $14.96
engine, engine / transaxle, engine parts, valve cover gasket 3.0 LITER, outer Left $14.96 $0.00 1 $14.96
engine, engine / transaxle, engine parts, valve cover gasket 3.0 LITER, inner Left $7.46 $0.00 1 $7.46
engine, engine / transaxle, engine parts, valve cover gasket 3.0 LITER, inner Right $7.46 $0.00 1 $7.46
engine, engine / transaxle, engine parts, intake manifold gasket 3.0 LITER $4.59 $0.00 6 $27.54
OEM Catalog - Subaru
GSKT CONTROL VALVE H $2.84 $0.00 2 $5.68
GSKT CYL HEAD $44.96 $0.00 2 $89.92
BOLT CYLINDER HEAD $5.14 $0.00 16 $82.24
FUEL INJECTOR SEAL $2.60 $0.00 6 $15.60
Catalog:
O-RING $8.68 $0.00 6 $52.08
Catalog:
HOSE-WATER $7.69 $0.00 1 $7.69
Catalog:
HOSE $8.57 $0.00 1 $8.57
Catalog:
HOSE WATER $4.16 $0.00 1 $4.16
body hardware, cowl, components on dash panel, level indicator seal kit W/DYNAMICS CONTROL $5.45 $0.00 1 $5.45
Catalog:
HOSE HTR IN $14.63 $0.00 1 $14.63
Catalog:
HOSE HTR OUT $19.30 $0.00 1 $19.30
Collision Catalog - 2006 - Subaru - B9 Tribeca
cooling system, cooling, oil cooler, hose assy $5.55 $0.00 1 $5.55
cooling system, cooling, oil cooler, connector hose $8.68 $0.00 1 $8.68
cooling system, cooling, oil cooler, oil cooler clamp $2.01 $0.00 2 $4.02
cooling system, cooling, oil cooler, water hose $9.28 $0.00 1 $9.28
cooling system, cooling, oil cooler, water hose clamp $2.38 $0.00 2 $4.76
Sub Total: $912.38
Shipping: : Ground (United States) 95.80
Tax: 0.00
Total: $1,008.18
