Octane requirements (2.5 XT) - Subaru Outback - Subaru Outback Forums
post #1 of 10 (permalink) Old 05-11-2012, 01:08 AM Thread Starter
Hi everyone. Still a relative newbie, but loving our Subie. We have an 05 XT 5-speed with 117k on it.
So what's the real dealio with the fuel requirements for these cars? Owner's manual specifies only premium but, depending who you believe, with the sophistication of the ECU it really doesn't matter what octane you put in the tank, so long as you're consistent. The car will figure out the mix, advance or retard as necessary, and I could be saving $5.50 a tank full by dropping down a notch or two.
Any good inputs?
Booker is offline
post #2 of 10 (permalink) Old 05-11-2012, 01:19 AM
Seabass's Avatar
Car: 05 OBXT 5eat stg1.2
It's required because otherwise you'll get detonation. The ecu will pull timing but gradually add it back in until it knocks again. In other words, your engine will have consistent knock. Any money you save from using regular gas will be eaten up by engine rebuilds. Not a good idea. By the way, there are cheap tools to log what's going on in the engine. So it might be worth it to buy a $20 vag-com cable and monitor learned knock on a tank of regular gas. Try to stay out of boost on regular though since piston rings like to break from detonation.
Seabass is offline
post #3 of 10 (permalink) Old 05-11-2012, 01:19 AM
slidog's Avatar
Car: 2012 Outback 2.5i Limited
I have heard somewhere on this forum about this, I think that particular model is recommended 91 premium fuel, but not sure if its required or not.
slidog is offline
post #4 of 10 (permalink) Old 05-11-2012, 01:20 AM
Seabass's Avatar
It's the h6 that recommends 91. The xt requires it.
Seabass is offline
post #5 of 10 (permalink) Old 05-11-2012, 01:22 AM
slidog's Avatar
I see.. makes more sense now.
slidog is offline
post #6 of 10 (permalink) Old 05-11-2012, 01:38 AM Thread Starter
Got it.
tanks, mang. I guess no cheap fuel for me.
Booker is offline
post #7 of 10 (permalink) Old 05-11-2012, 01:43 AM
rasterman's Avatar
Car: 2006 Outback XT Limited
Yeah, physics is kind of against you with that turbo equipment on board. As previously noted that H6 ECU can make adequate compensations, but it's just not gonna happen in the XT. Too much air & heat going in for the system to adapt for- you're doing the right thing sticking with 91 octane or better.
Focus on enjoying the acceleration of the car instead of feeling smug at the gas pump. It's the best way to make peace with an XT.
rasterman is offline
post #8 of 10 (permalink) Old 05-11-2012, 12:31 PM
Running regular in that XT would be baaaaaaaaaaaad.
Performance requires expense here. Premium fuel required, synthetic oil and short drain intervals recommended/required depending on the literature.
AWDFTW is offline
post #9 of 10 (permalink) Old 05-11-2012, 12:44 PM
jp1203's Avatar
$5.50/tank? Is 91/93 significantly more expensive than regular where you are?
93 is typically 20 cents higher than 87 here, and my Outback only holds 16.5 gallons (If I remember right...I doubt the Gen3 is too much more). For me, it's only around $3.00. I bought my H6 knowing that I should run higher octane in it, and would have known the same thing if I bought an XT. It's a few bucks, it really doesn't bother me.
Current Vehicle:
jp1203 is offline
post #10 of 10 (permalink) Old 05-11-2012, 04:54 PM
Bimmer's Avatar
What everybody else said, and somebody here will correct me if I'm wrong, but the real day-to-day economical issue is that if the ECU is retarding timing constantly, then it's wasting fuel (more advanced timing makes more power and is more efficient but risks knock with inadequate octane).
So, even if you're paying 5-8% more for premium fuel, you're probably making at least part of that back in better mileage.
Alternatively, if you try to save money by buying "regular" gas, you're probably burning more of it and saving little or nothing.
Bimmer is offline
