Car: 2007 Outback 2.5i
anyone know if the grille from the 2007 legacy sedan would fit my 2007 outback?
it looks close, i might have to find someone and do some measurements. anyone tried this yet? its one of the few modifications i'd like to try. |
Car: 2003 2.5 4EAT with AWP.
Same story.
Car: 2006 OBXT 5eat Newport Blue
True, the Legacy grill is about 3/4" narrower in depth and sits above the bumper cover in the same mount points. Width of grill ring is the same.
I liked the look of the simple Legacy wings rather than the Outback's horizontal shelf support brackets. If you're patient and meticulous you can do this. Got a '05 Legacy grill from the wreckers, studied the situation and went to work. Dremel-sawed the centers out of both grills at the extreme edge where it joins the ring. I found a single unmounted hacksaw blade is more accurate and maneuverable for the final cuts. Also removed the black support 'stretchers', leaving just the grill ring. Note - the '05-07 grills are one piece molds with integrated chrome. I think the 08 & 09 you can separate the chrome ring but the grills are a different shape where they meet the hood. You're left with 4 large side vacancies where the Outback center bars are molded in. Smooth down the edges and tape in exterior cardboard forms covered in tinfoil to shape & support the epoxy paste repair as it cures - you'll be pleased with the almost smooth surface. Using an epoxy compound Bumper Repair Kit and fiberglass cloth reinforcement I filled in & sanded out the ring sides and painted it graphite to match. Legacy center wings & medallion are in one piece (Chrome sections can be unscrewed from the back so they don't get scratched during the dirtywork) If you cut out the wings correctly they are a darn near perfect fit inside the modified Outback ring (after fitting and trimming and refitting). I made it fit tight and square then pre-drilled screw holes each side and the thickness of the wing keeps it leveled out. Back with a piece of matte black gutter mesh and add another screw or two if you like. Solid as OEM and I like the one-of-a-kind look. True Subaru guys always take a second look and the questions begin... Last edited by Old Davy; 11-16-2012 at 10:05 PM. Reason: more detail |
Car: 2006 Atlantic Blue OBXT Limited 5MT
Really cool! I thought about the grille swap for a long time and finally just gave up on the idea. But that's a ingenious way to make it happen!
#7 (permalink) | |
This! I will definitely have to try this then. just wanted to make sure somebody else was able to do it first. Anybody have the grille w/ wings and emblem from a 05-08 legacy available?
2007 Outback 2.5i - Silver - stock everything, head gasket and valve guides done @ 119k, new rims soon. 2009 Forester 2.5x Premium - Grey - stock, with CPO warranty. |
