2008 OB engine unicorns - Subaru Outback - Subaru Outback Forums
Old 01-08-2013, 11:28 AM   #1 (permalink)
Default 2008 OB engine unicorns
2008 subaru OB 2.5 5 spd manual w/ 48k miles.
yesterday my wife reported something she described as a "hickup" or "engine bump", while maintaining vehicle speed. So lower RPMS 2-3k range without a lot of throttle. It happened several times on her drive. The engine was warm too. I did not ask her hour fast she was going but I beleive it was slower speeds since it was snowing hard in Boise and the roads were a mess.
it sounds like an engine misfire to me but there is no check engine light on.
On another note over the past year or so, on a very rare occation, when coming to a stop using the brake and the clutch depressed, I have noticed that the engine speed dropping reallly low, well bellow idle but it picks back up pretty quickly and goes to idle.
any ideas? i think i still have the power traIn warrenty on it....
castiron is offline   Reply With Quote
Old 01-08-2013, 11:32 AM   #2 (permalink)
Car: 2013 OB 2.5i Premium/DDD Graphite Gray Metallic OP#2 Weathertec Window Deflectors
Sounds like ignition coils,check for carbon cracks.
Jim
Shadow 1100 is offline   Reply With Quote
Old 01-08-2013, 11:39 AM   #3 (permalink)
might try a scanner to see if there is a 'pending' code. freezFrame data might pick up on some odd fuel trim issue.
but , 'tune-up' type stuff might be a good idea - check the plugs, new plug wires, seafoam throttle body and half can/can in the tank, PCV valve.
Old 01-09-2013, 12:28 PM   #4 (permalink)
I have exactly both problems. The engine dipping happens for a couple of days after I unplug the battery. The engine stuttering seems to happen more when it's wet outside. Very interested if you find a solution.
I plugged my car into my laptop and ran FreeSSM. Using the Factory Service manual for an '09 (Mine is an '06), nothing jumped out at me. A couple of values seemed to be a little over or under, but nothing alarming. My main concern is that my AF Learning isn't 0% at idle like the manual states it should be.
ScoobyRu is offline   Reply With Quote
Old 01-09-2013, 12:41 PM   #5 (permalink)
that freessm looks BA. I'll have to get it going! I'd be interested to find out more about your setup.
Old 01-09-2013, 12:43 PM   #6 (permalink)
isn't this often a high voltage problem? plug wires or coil?
shadow100 might have got it right. Sometimes a mister bottle of water sprayed at the idling engine at night will show arcing near a bad wire or coil.
Old 01-09-2013, 03:38 PM   #7 (permalink)
Car: 2000 Outback 2.5L Auto
++ 1 Lucky Texan. First culprit: coil, due to symptoms.
DavidPeab is offline   Reply With Quote
Old 01-11-2013, 06:55 PM   #8 (permalink)
Car: 05 OBXT Limited AT
I didn't notice, 2.5i or XT?
mandarin is offline   Reply With Quote
