Power steering noise - Subaru Outback - Subaru Outback Forums
post #1 of 8 (permalink) Old 10-30-2013, 07:28 PM Thread Starter
Car: 01 obw 2.5 4eat
After replacing my head gaskets on my 01 obw my power steering pump is whining/cavitating. I admit I did leave the system sealed and laid the pump on the inner fender area so I'm sure all the fluid drained back. I drained and refilled the system with Lucas power steering fluid which seemed to do the trick until I let it sit for 5 days now it's cavitating again. I tried to bleed the system with the engine off and on. Should I plan on getting a pump or could it possibly be something in the rack?
vwtech is offline
post #2 of 8 (permalink) Old 10-30-2013, 08:24 PM
Moderator
cardoc's Avatar
There's a good chance that the return hose has a leak somewhere between the reservoir and pump. If not, then try flushing the system, and this time use Dexron III. Get the Lucas out.
cardoc is offline
post #3 of 8 (permalink) Old 10-30-2013, 09:17 PM Thread Starter
That could very possibly be the case, I noticed I can move the suction hose on the pump side with the clamps on. I will replace the clamps and the o ring on the hose as well.
vwtech is offline
post #4 of 8 (permalink) Old 10-30-2013, 09:46 PM
Moderator
cardoc's Avatar
And get the Lucas out of there.
cardoc is offline
post #5 of 8 (permalink) Old 10-31-2013, 08:36 AM
DavidPeab's Avatar
Car: Little Red, 2000 Outback H4 "Limited" - Onyx, 2008 LL Bean 3.0R
Feedback Score: 4 reviews
^^^ +1. Your car uses ATF for the power steering system not power steering fluid. Drain and refill with ATF Dextron III or better. You can use synthetic ATF if it rated as good as or better than Dextron III. It takes the heat better.
Set the Wayback machine to the year 2000 Sherman... when Little Red was problem free.
DavidPeab is offline
post #6 of 8 (permalink) Old 10-31-2013, 09:33 AM
Car: 01 OBW, 2.5 4AT
Same thing happened to me a year ago - the noise got worse as the weather got colder.
You could also run the engine, pull the intake piece, uncap the PS resivoir and see the bubbles churning up through the system.
a new o-ring on the pump inlet solved the problem. Pretty easy to do as far as car repairs go.
-John
'01 OBW 4AT, 170k
'09 Kia Sedona
Johnster is offline
post #7 of 8 (permalink) Old 11-02-2013, 04:02 PM Thread Starter
I replaced the o rings on the suction hose and installed a worm gear clamp on the hose and the problem has been solved. Thanks for your help.
vwtech is offline
post #8 of 8 (permalink) Old 11-05-2013, 10:35 AM
SubaruMike82's Avatar
Car: 2001 Subaru Outback - 2.5L w/ 5 speed MT
I have the same problem with my Outback when it's cold outside. The steering whines and I get a little bit of pulsation when turning. From what I have read it is likely the O-ring on the pump. However, when I went to Subaru they said I needed two of the O-rings. I haven't pulled it apart yet (will be doing so in the next day or two) but is this true?
SubaruMike82 is offline
