I am new to Subaru's and bought a 2001 outback automatic with 170k miles and a rod knocking. I am currently pulling the engine to swap it out. I did a lot of research and with the automatics you are suppose to remove the intake manifold to get access to the 4 bolts securing the flex plate to the torque converter. I did all that and when I pulled the engine the torque converter came with it.
My questions are do you think I did any damage to the torque converter?
As I understand it the main reason for not pulling the TC is because the installation is a lot easier with it already installed so now what do I do? I have pulled the converter off the back of the engine so can I just slide it back on the transmission? If I can slide it back on what about all the fluid that came out should I try to fill that before putting back together?
