Buzzing noise at engine startup - Page 2 - Subaru Outback - Subaru Outback Forums
Old 01-03-2013, 10:27 AM   #11 (permalink)
CSFiend's Avatar
Car: 03 5spd Outback wagon
Originally Posted by CNY_Dave View Post
After an oil change I crank it for a moment and shut the key right off 4-5 times, by then it cranks and runs with oil pressure.
You can floor the gas pedal and crank the motor to build oil pressure too -- the gas pedal floored turns off the fuel injectors. I do this with every oil change on my 2.5. Fill the oil filter, screw it on, fill the motor, and then crank the motor 2 or 3 times for 10 seconds each to prime the system a decent amount.
CSFiend is offline   Reply With Quote
Old 01-03-2013, 12:46 PM   #12 (permalink)
Car: 2003 LLBean H6 Outback
I know some cars were programmed to cut the injectors while cranking WFO (to help clear a flooded engine), didn't know subaru did that. Cool beans. I'll try it tonight (with a warm engine).
Old 01-03-2013, 09:06 PM   #13 (permalink)
BMike's Avatar
Car: 2002 Outback Station Wagon & 2011 Audi A4 PP
Of course it didn't seem as loud today but I tried to record, please ignor the video just trying to get audio:
It's astounding, time is fleeting.
BMike is offline   Reply With Quote
Old 01-08-2013, 06:30 PM   #14 (permalink)
The 2003 H6 apparently does not have this feature- maybe this is on throttle-by-wire systems only?
Even with the injectors on it does effectively clear a flooded engine.
Old 01-08-2013, 07:16 PM   #15 (permalink)
CSFiend's Avatar
Interesting. Mine isn't throttle-by-wire; I have a physical throttle cable from the pedal to the throttle body. But I have the same year H4; maybe it's a difference between motors... but that seems unusual.
Stupid question, but was it all the way to the floor? Any chance there's a floor mat preventing full throttle? It'd have to be a heck of a mat though... hmm.
Old 01-08-2013, 10:48 PM   #16 (permalink)
cardoc's Avatar
It may be a curled up weather tech.
I have never noticed a long start period that was intentionally initiated by the ECM. What it is most likely doing is taking longer to start due to the amount of available air, lack of good vacuum and low injector cycle that is allowing it. It doesn't get the proper air/fuel mix with WOT starts so it won't really create combustion to start it.
In a "flooded" engine, the WOT allows for more air to mix with the already high concentrate of fuel and with the engine rotation pumping the mix in/out, thinning the fuel portion, it eventually starts.
Old 01-09-2013, 09:37 AM   #17 (permalink)
No floor mat in the way, was fully floored.
I know the feature does exist on some cars out there...
Old 01-09-2013, 05:57 PM   #18 (permalink)
CSFiend's Avatar
Now I'm confused why mine behaves this way.
