Sleeper vdc - Page 21 - Subaru Outback - Subaru Outback Forums
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
post #201 of 675 (permalink) Old 11-19-2012, 01:34 PM
Car: DIY-Turbo 2.2l OBS 12.89s 1/4mile @ 106.17MPH
Glad you made it to the track.
I tried to do the same this weekend -
Friday, I called & got a "track closed will be open Sat. message"
Sat., I drove 80 miles to the strip only to find it closed - so I had to head 80 miles back home with no 12s run this year...
Here is a link to my favorite HP calculator (set for RWD cars / 20% driveline loss so the crank hp numbers need a bit of tweeking for Subaru driveline losses).
Horsepower Calculator, calculate hp from et, trap speed, calculate tire diameter, mph and rear end ratio.
I estimated weight @ 3600lbs with driver & like I said previously the MPH actually tells more about the cars power than the time (stock 4eat = slow launcher = slower ET, high stall converter + a worked valvebody will take about 1 second off of the 1/4 mile time on turbo Subarus).
susiemk is offline
post #202 of 675 (permalink) Old 11-19-2012, 11:21 PM Thread Starter
Moderator
cardoc's Avatar
Its more of a get up and go faster on the expressway kinda car. 60-100 is **** quick.
The torque converter lock up speed slows my launch.
In the run with the red Camaro, if I'd had another 1/16 mile, I would have passed it. I was catching up.
cardoc is offline
post #203 of 675 (permalink) Old 11-20-2012, 10:02 AM
I know what you mean as I have a 4eat '94 Legacy SS (Turbo) with a EJ20G swap & launching is its weakness.
When I took it to the dragstrip it ran 14.50 @ 96.96MPH in the 1/4 mile on a stock longblock EJ20G + all of the bolt ons (FMIC, 3" TBE, Intake), TD04 turbo @ 15psi, 3450lbs weight - 60' time was the problem with mid 2's being the average on no brake torque 700rpm idle launches.
I actually got a high stall toqure converter for it as well as a manual shift controller but have not had a chance to put them on.
susiemk is offline
post #204 of 675 (permalink) Old 11-20-2012, 10:19 PM Thread Starter
Moderator
cardoc's Avatar
What are you doing, staring at them in deep contemplation? Put em on.
cardoc is offline
post #205 of 675 (permalink) Old 11-21-2012, 10:23 AM
Too many projects not enough time -
I have to play with my kids
I have to go to work
I'm concentrating on the OBS-t as it is almost in the 12's so I've been getting all of the suspension / brake crap I have for it on it
I'm trying to eek out a bit more HP from my buddy's drag car I tune, initial goal was running 8's but now I'm trying to get it into the 7's (best 1/4mile run is 8.41@161, but runs in the 8.40's like a clock - I'm thinking e85 + 5" exhaust + a ring & pinion swap should get me there on current BW s475 turbo - its a 2250lb, 1.3 liter (80 cu/in) 13b powered car making about 730whp / 876 chp @ a low 34psi of boost)
I'd love to get the car to 840 whp / 1000+chp - 1000hp is a nice round number to tell folks
I'm lazy
If you can get your hands on a t-converter from your wagon IPT will modifiy it - this may be enough to get you into the 13's!
? if Trans-go makes a v-body kit for your year 4eat (this will probably fix "the problem" the runt felt), if they dont IPT can do that too (expensive though) - they definately have performance 4eat rebuid kits for Subaru 4eat's...
susiemk is offline
post #206 of 675 (permalink) Old 11-22-2012, 12:51 AM Thread Starter
Moderator
cardoc's Avatar
That 2-3 shift is strange. It doesn't do it all the time. And the transmission doesn't try to make the shift at the same rpm consistently with my foot on the floor.
Shifts normal otherwise. I did have an idea I am going to try. See if it makes a change in the 2-3.
Never made a high rpm 3-4. I always have to let off the throttle. Fastest straight line run so far has been about 122 mph in 3rd with plenty of room to 7000 rpm. I don't know what the top speed is on this thing. I plan on taking it to the Texas Mile next spring to find out.
I do know that even at 122, it rides smooooooooth.
cardoc is offline
post #207 of 675 (permalink) Old 11-22-2012, 04:44 AM
Timberwolf99's Avatar
Car: 2000 Outback Limited, Dual Range 5 Speed
Saw ring and piston swap, then saw 13b asked myself that's not right? Then retread your post susiemk and all became clear, what do you have the rotor in.
Don't follow me i may be looking for a cache!
Timberwolf99 is online now
post #208 of 675 (permalink) Old 11-22-2012, 07:47 PM
Car: 2003, obs, h6, 85k on motor, 160k on trans
if im ever near austin texas I would love to see this machine. awesome thread, i enjoy coming and reading this forum and thread on my breaks at work! keep up the great work cardoc.
mchance1984 is offline
post #209 of 675 (permalink) Old 11-29-2012, 12:36 PM
Just saw this sorry for the late reply
I was talking about a ring & pinion swap in the rear differential for a different final drive ratio.
My bud is an old school import drag-racer from Puerto Rico & has 2 KP61 Toyota Starlets with Rotary swaps.
"Fast" car is a simple old school back half'd ladder bar car with a G-Force 2000 sequential dogbox transmission, spec triple disc minilite clutch, PP 13b homemade from a $100 donor 6-port 13b, ford 9" rear, smallish 12" tires - again best 1/4 mile time 8.41 @ 161.50MPH...
"Slow" car has everything above except is on a 70's toyota celica 5 speed transmission, has a cheap clutchnet PP & custom single disc, has a chevy 12bolt rear, & small 10" wide tires - its best 13b 1/4 mile time is 9.78 @ 141+ MPH (ran 9.97 @ 133MPH on a pp12a)
Everything is fab'd, built, or tuned by myself and/or my buddy - he is an excellent welder with a gift for porting/polishing / fabricating, while I have alot of patience when it comes to getting all clearances perfect on rebuilds / new builds & can tune the cars w/o too much drama.
I also spec the cars out in terms of combinations of turbo, I/C , exhaust, CR, fuel, ecu, etc + I have fun eeking out that last bit of performance out of these cars by learning more on suspension tuning, wheelie bar heights, tire pressures etc...
Trying to talk him into E85 (available near one of the dragstrips we use) but he is stuck on VP race fuel @ the moment.
susiemk is offline
post #210 of 675 (permalink) Old 11-29-2012, 02:59 PM Thread Starter
Moderator
cardoc's Avatar
We are bored today at the shop. Got the car dusted.
cardoc is offline
