LinkBack | Thread Tools |
Rating:
Car: 2004 Outback Limited 2.5i
Hi All,
My P0420 code started this past February and it has been driving me crazy. I started with replacing the pcv, code still there, then I used the Seafoam method. That cleared the code for a few weeks just enough to help me pass my inspection in August. After that the code has been coming on persistently. I don't have drive-ability issue, the car runs like a champ, no lost of gas mileage whatsoever when the code is on. So this past 3 weeks I have been dedicated my time to chasing this problem. I cleaned the EGR, my throttle body, flushed the radiator fluid, check the thermostat..no go. Replaced the spark plugs, new spark plugs wire. Tried the anti-fouler, first using 1 then using 2, that made it worst, throw me 3 more codes P2096 and P2098, and P0137. So I took the anti fouler off. Replaced the front sensor with Subaru/Denso sensor..no go, replaced the rear sensors with Subaru/Denso sensors, no go. I called the dealer, they wanted $2600 to replace the cat, not going to spend that much money on an 04 with 146K miles. So before I replace the cat converter which we all know is expensive even if I do it myself, I threw a hail mary and tried the diode hack. Viola!!! It has been 3 days now with 6 drive cycles and no check engine light, all system back to ready when I checked it this morning with my code reader. Finger crossed. Here is the link to the hack 2000 Subaru Outback P0420 Electrical Hack Dan's Toolbox Sorry for the long post and I hope this will help others that are having the same problem as me. |
This is the "fix" used when an engine is tuned for high boost levels and rich fuel mixtures with catalytic converters removed from the exhaust system to trick the computer into thinking the cat is there and functioning.
No offense, but all you accomplished was tricking the ECM. You still have a problem and at some point, it will rear its head. Have you looked at P0420 Diag ? |
#3 (permalink) | |
no offense taken. i did read and watch your post before i started chasing this down, very helpful. i did most of the items you mentioned like tune up, checking my oil, replacing the radiator fluid, checking exhaust leak etc etc and none of these fix the code.i wish we have tech like you up here in NH. i did call the dealer to ask them for diagnostic but they said all they do it hook it up to a computer and watch the graph or some sort to determine but they are very adamant about replacing the cat. i am hoping to find an indie subaru repair shop to get this check out and i am also hoping / crossing my finger to have save enough money in another month or two to trade it in and get the new Crosstrek. i do appreciate your post on the P0420 diagnostic, which is very helpful |
Car: O3 Sub Outback Wagon 2.5L AWD 4EAT w/ All-weather Package
Just a quick note on P0420, I had this code just before the P0032 (bad heater on forward O2 sensor) took over eliminating P0420.
89 Ford Mustang GT Ragtop 400HP 97 Ford E-150 Starcraft Conversion Van 02 Ford F-150 03 Subaru Outback |
For some reason my OBS-t would not go into ready mode with an electricic CEL "fix".
So I've used 2 spark plug non-foulers on the REAR o2 sensor (1 untouched screwed into the exhaust then 1 drilled out to allow the rear o2 sensor to thread into it (2 have to be used together to eliminate the cel)) for many years & get no CEL + all systems are "ready". This has worked on EVERY car I've tried it on - Hondas, Toyotas, Various Subarus. |
Hey Toro168, thanks for the post. I am having the exact same issue on my wife's 08 subaru outback. I had the P0420, installed the anti-fouler, and then started getting the P2096 and the P0137 which is what brought me to your post. I am going to give this a shot, but have a few questions. Has your CEL stayed off since the fix? Also, I was thinking about just taking out the rear O2 sensor and installing the diode on its wire in the engine bay. Is that where you installed it, or did you go back inside the car and do it there? Thanks!
#7 (permalink) | |
There is not a quick fix for anything. The core of the issue needs to be located and repaired. In your case the computer isn't getting anything or is always getting a low reading from the rear O2 sensor. Another thing that causes this if the O2 sensor is in fact good is a clogged CAT and no anti fowler or diode will correct it.
SubarCharged 2001 VDC AWD Super Charged 3.0 Raptor VLLC Water Cooled Ultralight Denso WRX 410cc Injectors (Soon DW650cc) Silicone Intakes tubing w/GReddy TypeS Type 13 WTA intercooler with 10x13 radiator w/7" fan Aeromotive FPR & DW300 pushing E85 Innovate Motorsport WB, EGT, VAC/Boost Gauges Projector HID Headlights/HID Fogs Clarion DD, Polk Audio, Kicker Sub, SO S1350 Amp All ECM Mapping by ED @ XRT ![]() All the goodies with an extra kick in the seat |
#8 (permalink) | |
The CEL has been off since I did the fix. I did exactly the way you are going to do. I took the sensors off and splice it close to the connector in the engine bay. That way I was able to keep the splice from getting wet. One thing you want to pay attention is the which end of the diode you splice. Good luck. |
#9 (permalink) |
^The diode won't work with his problem. The computer is reporting a circuit issue, not an emission issue. Putting the diode in would be the same as taping the diode to the rearview mirror.
#10 (permalink) | |
code P2096- wtf - Page 2 - Subaru Forester Owners Forum Look @ the last few posts as guy on this site has the exact same problem you have. |
