Why is my serpentine belt continuously shredding? - Page 4 - Subaru Outback - Subaru Outback Forums
Old 01-02-2013, 08:08 AM   #31 (permalink)
So you are thinking the compressor? Is it possible to just replace the pulley and not the whole compressor?
wogmail is offline   Reply With Quote
Old 01-02-2013, 08:23 AM   #32 (permalink)
cardoc's Avatar
Originally Posted by signage View Post
It appears to me that the AC compressor pulley is the culprit!
I agree.
The AC compressor pulley is most likely coming loose or there is internal issues. The belt is on the crank the way it is supposed to be. All the others are shifted. In his last set of photos it's off the PS pump. In the first set, it was on the pulley wholy. The distance between the crank and AC with the direction of the rotation leaves the AC pulley as he culprit and then it walks the other pulleys after the shredding starts. Couldn't tell you why it is staying on the crank except maybe its because the tensioner is holding in place since it so close.
It's either that or the belt has been installed incorrectly every time where it wasn't placed on the AC properly.
I have an AC compressor just sitting in my shop with less than 50k on it. Its an 02 off a JDM. I couldn't use it on my 01. The plug is different. Post a pic of the top of the compressor on your car and if it matches this one for line position and plugs, I can send it to you.
Old 01-02-2013, 08:37 AM   #33 (permalink)
I had thought about the "smooth" pulleys, but discounted it when I looked at the path of the belt. (see below) The two flat pulleys are on the tensioner and the idler. The other pulleys, on the crank, AC compressor, alternator and p.s. pump are grooved in some way. If one of the idlers is not "square", the belt, as it passes over the idler will indeed tend to move off center. But looking at the path, in both cases of smooth pulleys, the next pulley is one of the grooved ones. If the smooth pulley is causing the belt to go off center, one would expect the belt to jump grooves on the following pulley, but that's not the case. It's jumping at the compressor, and both the pulley before the compressor, and the pulley after the compressor, are also grooved, and the belt isn't crossing the grooves on those.
OK, definitely a fair point that we are seeing things AFTER damage has occurred and the belt may be shifted on the idler due to damage.
does the belt look OK to everyone else on the Alt. in this pic?
Is there a measurement someone could make on the A/C to determine if its pulley is forward several mm from normal position? It certainly doesn't appear tilted enough to throw the belt off 2 grooves.
Old 01-02-2013, 09:21 AM   #34 (permalink)
Serpitine belts are complicated systems. The only things that have changed in this car are the idlers. The other items have not been touched. All the adjustment is on the tensioner in this discussion. Adds up, so where you think it should be the belt turns and twists more stresses and torquing (twist) of the belt adds up
The belt pulls the accessories, so it makes sense if the belt before the alt is out of wack, it can jump between the alt and ac compressor as the belt is loaded and unloaded due to engein RPM, alt and ac load.
Old 01-02-2013, 10:47 AM   #35 (permalink)
I keep thinking the idler bolt could be cross-threaded or bent but, it's just one of several parts any one of which could be problematic.
Old 01-02-2013, 10:58 AM   #36 (permalink)
rasterman's Avatar
Car: 2006 Outback XT Limited
To my eye, it looks like the idler is positioned wrong and is allowing the belt to walk off the rear edge. The alternator pulley would be correcting this, but chewing the rear edge of the belt in the process.
I have not owned a 3.0 engine so I'm not as familiar with the layout as other folks on this thread.
I think the first belt failed because it was old, and the subsequent belts have failed because something isn't right about the replacement idler.
I'd still want to check the crank pulley for separation just in case.
Also, these belts have likely polished some metal to mirror-grade shine, wherever they've been dragging and snapping. What looks freshly polished in there?
Old 01-02-2013, 11:05 AM   #37 (permalink)
Yes the belt should be sitting in the middle of that idler.
Old 01-02-2013, 12:11 PM   #38 (permalink)
Car: 05 LL Bean Outback Wagon
Most air conditioning compressors also have the rubber mounted pulleys!
signage is offline   Reply With Quote
Old 01-02-2013, 12:53 PM   #39 (permalink)
Car: 2003 LLBean H6 Outback
Waaaay too much of that idler is showing. The pulley is much too far out.
Old 01-02-2013, 04:32 PM   #40 (permalink)
Here are pics of the AC compressor:
Photo Album - Imgur
My normal mechanic said that the idler was sticking too far out as well.
How can I fix this? I am planning on taking the car back to the dealer tomorrow and trying to at least get my money back for my parts, although that may be wishful thinking.
What should I do guys? I am not a mechanic. Should I give up on the dealer and just take the car to my regular mechanic who told me the idler was sticking out to far to begin with? How could they put it on wrong?
I feel like I have to deal with the dealer at this point because they have already taken so much of my money and seem to have done nothing.
