EGR valve troubles - Page 2 - Subaru Outback - Subaru Outback Forums
post #11 of 21 (permalink) Old 11-16-2009, 11:41 PM
No, the PQR labels are all on/near the top. See the linked photo for the tube in the center bottom ... that's the one I was referring to.
http://www.subaruoutback.org/gallery...14741aa020.jpg
RobLog is offline
post #12 of 21 (permalink) Old 11-17-2009, 03:36 PM Thread Starter
Car: 2009 Outback Wagon
Pulled the BPR of today and I can blow threw it either way. I can even block off the P,Q, and R ports and it still lets air go either way. Is it bad for sure? Roby
After I posted this response I visited ANSWERS.COM in researching the BPR valve. This what they said about the Valve:
Answer:
make sure you have vacuum to the transducer, i believe there will be 2 hoses coming from the throttle body. make sure that the metal line that connects to the bottom of the transducer is not clogged with carbon. if you have vacuum and that line is clear, take the hose that goes to the egr vsv solenoid off the transducer and rev the engine up. if it is good you will have vacuum through the transducer, if its bad no vacuum will be there.
Roby is offline
post #13 of 21 (permalink) Old 11-17-2009, 07:37 PM
Yes, that makes sense. BTW, the BPT port labeled "Q" is the one that goes to the EGR Solenoid Valve and it should have continuous vacuum with the engine running at operating RPMs. At approx. 3000 RPM, the computer sends a signal to the EGR solenoid to open and allow the vacuum through to the EGR valve which moves the EGR valve diaphram and opens the valve.
If you haven't already run across this, check out the document at:
http://www.vcertt.org/news/11-02.pdf
Great how-to on troubleshooting a P0400 on a 97OB.
RobLog is offline
post #14 of 21 (permalink) Old 11-17-2009, 08:50 PM Thread Starter
Thanks, Great article from vcertt. Will do some good testing in the next few days. will keep you posted. Thanks again.
Roby is offline
post #15 of 21 (permalink) Old 11-22-2009, 11:01 PM Thread Starter
Good news on the trouble shooting. By using the guide at "vcertt" (earlier post) I was able to pinpoint my trouble to the Backpressure transducer. I also found that by using a small hose and appling mouth vacumm to the different ports in the EGR system you can litterly check each component for vacumm or postive pressure without taking any of them off the car. I was even able to check the operation of the EGR solenoid by connecting my small hose to the input port of the solenoid and rev'ing the engine to half trottle and with mouth vacumm I could operate the EGR valve pintle, by making that test I knew the 12v and ground were operating the solenoid and the passage was good going the the EGR valve. I have not replaced the BPR yet as I am still scanning the internet for the best price. So far it's $53.22 plus shipping. Does anyone know of a good place to look? I'll keep you posted when the light is actually OUT! Roby
Roby is offline
post #16 of 21 (permalink) Old 11-23-2009, 02:24 PM
Congrats on the successful detective work.
www.subaruonlineparts.com has the BPT for $51. They're in NY, I think. As nearly always, shipping charges stink.
If a local dealer will sell it to you for list, $73.92, it might be worth it to save time if they have it in stock. Most of them charge list+, though.
RobLog is offline
post #17 of 21 (permalink) Old 11-29-2009, 03:23 PM Thread Starter
GOOD NEWS. I was able to find a '96 Legacy wagon in the junk yard that had a good BPR. I got it for $10.00 and have had installed for about a week with no CELight. The Legacy also had a EGR valve and the solenoid, I think I could get them for almost nothing, just for spares. About the solenoid...I couldn't see very well in how it comes off. Does anyone know how it is removed?. Looks to me like it maybe could have 1 0r 2 bolts or a clip...can't see beyond the valve very well with it still in place. Any help would be appreciated. Roby
Roby is offline
post #18 of 21 (permalink) Old 11-30-2009, 02:12 AM
The solenoid is held on by one bolt ... 12mm head IIRC.
To get a socket on the head, I had to loosen the 8 intake manifold bolts enough to raise the IM about 1/2". If you have a thinwall deep socket, you may not have to do this.
RobLog is offline
post #19 of 21 (permalink) Old 12-14-2009, 02:37 AM
Car: 98 outback, 2.5L
egr circulation issues
I have been fighting a PO400 code for a couple of months now. I went through the entire system. Found a bad BPT. replaced it with the same issue again. I found a clogged PCV hose. Pulled the tube and followed it down into the block. I attached an air hose to the tube that t's off and feeds into the rocker covers and blew out chunks of carbon. I replaced the PCV valve, and it runs like a new car.
Jason hamelin
Jason Hamelin is offline
post #20 of 21 (permalink) Old 02-17-2010, 05:43 PM Thread Starter
Well my cel light has stayed off from my last post when I changed the BPT until now. In testing this time I found the EGR solenoid to be bad. I removed the solenoid and applied grd and batt to it and I could barely hear it click. It didn't allow any air through it. I tried cleaning the passages but no luck. Relay is just not pulling up. I have ordered one..will be here next week. I my testing I found that the hose coming to the bottom of the BPT...called the "exhaust gas pressure port" was wet.
I'm not sure where this hose comes from, but it is (exhaust gas pressure) so i'm thinking it could be condensation, much like what comes out of your tail pipe. . If so...that could be the cause of my BPT going bad and now the solenoid. While waiting of the solenoid I bypassed the solenoid and went from the BPT to the EGR valve. Everything works fine now, but I'm sure the CEL will return because the Egr valve is not suppose to operate until the veicle is warmed up and now it operates right from the get go. Back to condensation problem, not wanting to moisten the BPT or the EGR valve I have installed a OIL/WATER separator in line with exhaust gas port hose. This moisture I'm getting in that line, is it a sign of something much bigger...like a head gasket? where could that moisture be coming from?. Any help would be greatly appreciated. Roby
Roby is offline
