1998 OBW possible drivetrain issue? - Subaru Outback - Subaru Outback Forums
Old 02-10-2013, 10:09 PM   #1 (permalink)
8kGoodENuff's Avatar
Default 1998 OBW possible drivetrain issue?
Was wondering if anyone here has any ideas what can be going on. The symptoms have me a little stumped.
Recently, when the wagon reaches about 50 mph and up to about 60 mph, I've noticed a shallow vibration in the area of my feet either coming from underneath or from the center console area. In addition, there is a deep drone, whine with this vibration is going on. I checked the front differential fluid and the tranny fluid and all is up to proper level. There is no vibration in the steering either. Also, when I get to my destination, I can smell what I think is the tranny fluid... same smell I always notice when driving in snow where the AWD system is consistently being engaged and disengaged.
Other symptoms that have been occurring previously but not sure if they are all tied together in any way:
-When making right turns (right turns only) at typical intersections, I get a heavy vibration coming from somewhere in the front. Vibration is not during the actual turn, but when accelerating back to speed while unwinding the steering wheel back to the straight position. Once the car is driving straight again, the vibration is gone. The vibration is somewhat rough, scale 1-10 (10 being very heavy), I rate it at about 7.
-Tranny hesitates when shifting between 2nd & 3rd gear. Does not hesitate at any other gears, only from 2 to 3. The tranny will come out of 2nd gear, float for 2-3 seconds, and then catch 3rd gear.
Again... I'm totally stumped. I've read anything from a possible bad drive axle to a bad U-joint for the driveshaft. The axle makes sense due to location where I can feel the vibration coming from. If it were anything related to the driveshaft, I would feel it in the seat.
Thank you in advance,
Andre
2006 Honda S2000 (Good Weather Warrior)
1998 Subaru Legacy Outback (Extreme Weather Warrior)
2012 Subaru Forester 2.5X Premium (Wifey's Ride)
2013 Super Cycles Scooter: 1500-Watt Brushless Motor (702 MPGe... Ohhhh the savings!!)
--------------------Previously Owned--------------------
1986 Volkswagen Jetta Diesel (Loud but miss 55 mpg... lol.)
8kGoodENuff is offline   Reply With Quote
Old 02-12-2013, 09:03 PM   #2 (permalink)
I guess I'm not the only one that is confused about this situation... Lol.
Andre
Old 02-12-2013, 09:19 PM   #3 (permalink)
Andre
Vibrations at 60 mph - your car is old enough that a universal joint in the driveshaft may be seizing/failing.
Flush the transmission fluid and see if that has nay effect.
The 2-3 shift, does the engine rpm flare at all, or does it stay constant and just feel like nothing is happenining.
How many miles.
Do all the tires match, equally worn and properly inflated?
Old 02-13-2013, 12:59 PM   #4 (permalink)
Car has 188,300 Miles. How would you check for a bad U-Joint?
I was planning on flushing again once the weather got better. Didn't think it would be needed since I did it about 15,000 - 20,000 miles ago, but doesn't hurt to do it again.
Tranny & RPM stay constant and feel like nothing is happening, and then engages next gear.
All tires are worn the same and I check tire pressure every 2-3 weeks... so should be ok.
Thank you,
Andre
How many miles.
Old 02-13-2013, 02:00 PM   #5 (permalink)
a bad axle might exhibit some of the symptoms.
but, you may have 2 problems at once.
Old 02-13-2013, 02:17 PM   #6 (permalink)
Car: 2000 Outback 2.5L Auto
+1 on the axle
DavidPeab is offline   Reply With Quote
Old 02-13-2013, 03:39 PM   #7 (permalink)
I have noticed that as the 4eats get older the like fresh fluid more often. What I did was switch to a drain and fill every other oil change.
As long as there isnt a flare it isnt anything to get too excited about. What helped resolve mine when it did it was a replacment MAP sensor form a scrap yard (lower mileage car) and a new ground from the engine to the battery. They may not resolve it for you, just a suggestion.
Right turn can be an outer or inner CV joint. The CV can also cause the high speed vibration. What condition are the boots in? They dont have to have torn boots to wear out.
Old 02-13-2013, 04:59 PM   #8 (permalink)
cardoc's Avatar
To verify an axle vibration, cruise with the your foot on the accelerator creating torque on the drivetrain at the point the vibration occurs, then take your foot off the accelerator. If the vibration quits, its the axle. You just have to figure out which one from there by feeling for which side it is coming from or jack it up on stands or a lift and put it in gear and look for the one that wobbles.
SubarCharged
2001 VDC AWD Super Charged 3.0
Raptor VLLC Water Cooled Ultralight
Denso WRX 410cc Injectors (Soon DW650cc)
Silicone Intakes tubing w/GReddy TypeS
Type 13 WTA intercooler with 10x13 radiator w/7" fan
Aeromotive FPR & DW300 pushing E85
Innovate Motorsport WB, EGT, VAC/Boost Gauges
Projector HID Headlights/HID Fogs
Clarion DD, Polk Audio, Kicker Sub, SO M1350 Amp
All ECM Mapping by ED @ XRT
naysayers
All the goodies with an extra kick in the seat
Old 03-17-2013, 11:06 PM   #9 (permalink)
I just had a very similar vibration. My right side axle boot lost all the greese, and the joint finally gave out. I replaced both front axles just because my Leggy Outback Wagon has a 160,000 miles plus. I paid $50 for each side at Napa auto parts rebuilt. Best of luck!
Eddie
Eddie99OB is offline   Reply With Quote
