Access Key Not Detected - NOW SOLVED!
I have a new headunit in my 2015 OB now - there is a separate thread covering the headunit - http://www.subaruoutback.org/forums...1-aftermarket-headunits-finally-incoming.html
Today I removed the headunit, pulled apart the dash and centre console to install a USB panel in the centre cubby hole, in place of the standard USBs. Major job, but all put back together OK.
Headunit is working. I have removed and reinstalled the new HU quite a few times before this, without any problems.
PROBLEM:
Now when I try to start the engine I get "Access key not detected" on the centre display. Engine won't start. If I put the key fob on the start button and push the engine will start and I can drive around. Just keep getting the error message about the access key. I can lock and open the doors without pushing the fob buttons, so the fob is being detected for remote access. I can lock and open doors by pushing fob buttons.
What have I done??? And how do I fix it? Hope someone can help. It is now the weekend here, so can't contact the Subaru dealer.
PROBLEM:
