Subaru Outback Reverse/Backup LED Bulbs! Plug & Play Install! Ships Same-Day! - Subaru Outback - Subaru Outback Forums
 9Likes
post #1 of 50 (permalink) Old 05-21-2015, 09:10 AM Thread Starter
Supporting Vendor
Diode Dynamics's Avatar
Car: 2015 STI
Arrow Subaru Outback Reverse/Backup LED Bulbs! Plug & Play Install! Ships Same-Day!
Subaru Outback Reverse Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your Outback's reverse light or backup light bulb (921 / 3156 / 1156 sizes). We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two LED bulbs for perfect fitment in your Outback model year selection.
Shop Now: 2004-2004 Outback Sedan Backup/Reverse Light
Shop Now: 2000-2004 Outback Backup/Reverse Light
Shop Now: 2005-2007 Outback Sedan Backup/Reverse Light
Shop Now: 2005-2015+ Outback Backup/Reverse Light
2000-2004 Outback Model Years(3156):
2005-2015+ Outback Model Years / 2005-2007 Outback Sedan Model Years (921):
2000-2004 Outback Model Years (1156):
Bulb Design
(For 1156 / 3156 Bulb Models)
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
(For 921 Bulb Models)
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
Included in your order is TWO BULBS to fit your Outback or Outback Sedan selection.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
(3156 / 1156 Bulb Models)
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
(921 Bulb Models)
HP5: (92 lumens) Slightly lower brightness than OEM bulbs, but still provides the crisp, modern instant on/off of LED technology.
HP36: (210 lumens) Slightly higher brightness than OEM bulbs.
XP50: (410 lumens) Much brighter than OEM bulbs.
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures. Please click here to learn more about LED brightness measurement.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
XP50 Model Shown
Diode Dynamics is offline
post #2 of 50 (permalink) Old 05-27-2015, 01:15 PM
boxterfan67's Avatar
Car: '02 Bean H6, AWP & ORP, factory hitch
How about posting some prices?
boxterfan67 is offline
post #3 of 50 (permalink) Old 05-27-2015, 01:18 PM Thread Starter
Supporting Vendor
Car: 2015 STI
We have complete Outback listings with pricing information listed here on our site: Subaru Outback LED and HID Lighting
Thanks!
Nick C.
post #4 of 50 (permalink) Old 05-27-2015, 01:28 PM
Thanks, I'll give your website a look.
post #5 of 50 (permalink) Old 05-27-2015, 01:30 PM Thread Starter
Supporting Vendor
Car: 2015 STI
We offer free-shipping for U.S. forum members as well!
Don't forget to send us a PM!
Nick C.
post #6 of 50 (permalink) Old 06-01-2015, 06:36 PM
KentuckyOutback's Avatar
Car: Twilight Blue 2015 3.6R with Eyesight
Just ordered the HP36 bulbs, can't wait! I figure it'll light up better, making the backup camera allot clearer.
Diode Dynamics likes this.
Stultus est sicut stultus facit.
There are Three kinds of people. Those who can count, and those who can't...
KentuckyOutback is offline
post #7 of 50 (permalink) Old 06-02-2015, 09:29 AM Thread Starter
Supporting Vendor
Car: 2015 STI
Thanks for ordering with us Don!
Looking forward to hearing your feedback
Nick C.
post #8 of 50 (permalink) Old 06-02-2015, 04:02 PM
Sandbag's Avatar
Car: '15 Wilderness Green Outback 3.6r LTD with EyeSight, '16 Dark Gray Forester LTD with EyeSight
I ordered and installed the XP50. Easy install but can't really give a good appraisal as I havn't backed up when it's dark out. They sure seem a lot brighter.
If you don't know where you are going, you might wind up someplace else. - Yogi Berra
Sandbag is offline
post #9 of 50 (permalink) Old 06-02-2015, 05:33 PM Thread Starter
Supporting Vendor
Car: 2015 STI
Thanks for ordering with us!
Nick C.
post #10 of 50 (permalink) Old 06-29-2015, 11:09 PM
Sorry this took so long. I got the lights and installed without a problem. They really make a big difference!
Name:	LED lamp test.jpg
