2008 ecm - Subaru Outback - Subaru Outback Forums
Old 02-09-2011, 04:17 PM   #1 (permalink)
Car: 2008 Outback 2.5i, silver, 2.5 w/manual tranny
Default 2008 ecm
Where is the ECM (processor, computer, whatever you wanna call it) on a 2008 2.5i?
And what components (besides the ECM of course) control the idle of these cars? Is there only the mass airflow and the drive by wire system to take care of it? I don't see an IAC on this thing.
2008wagon is offline   Reply With Quote
Old 02-10-2011, 07:27 AM   #2 (permalink)
The ECM is under the carpet on the sloped (forward) portion of the front passenger floor, more or less below the glove box.
The ECM controls the engine speed, whether idling, running, on cruise control etc, by controlling the throttle (throttle plate position), the ignition timing, and the fuel delivery through the injectors. The ECM uses a wide range of inputs, including engine speed sensors (e.g. crank, camshaft), knock sensor, air intake temperature, accelerator position, and fuel sensors (e.g. O2) and based on its programming adjusts the outputs to the throttle, timing and fuel accordingly.
plain OM is online now   Reply With Quote
Old 02-10-2011, 09:50 AM   #3 (permalink)
OK, underneath the carpet in that area, I see the ECM. I also saw a 2 pin connector...a male end and a female end....just hanging right there like it had somehow come unplugged. So I plugged them in.
Now I have a flashing engine light. What did I just do?
I've got a scan tool, so I can turn this light off, but I wanna know what plugging those connectors together did to cause it to flash in the first place?
Old 02-10-2011, 11:22 AM   #4 (permalink)
Car: 2003 2.5 4EAT with AWP.
Were the connectors green? If so you just put the car in diagnostic mode. Unplug them.
2003 Outback: "Kaylee". 128,000 and counting.
Old 02-10-2011, 05:58 PM   #5 (permalink)
Yes, they were green. I unplugged it and the light went off.
