1999 outback cold engine stall - HELP - Subaru Outback - Subaru Outback Forums
Old 03-28-2011, 11:32 PM   #1 (permalink)
Default 1999 outback cold engine stall - HELP
I have had a problem for the past year or so...help! 1999 outback (Love it)!
Problem:
1) Cold morning, start the engine,,,I live where It is a long down hill (a few miles) to the bottom of the hill...
2) When I get to the bottom of the hill, I push the clutch in and the engine stalls.
3) Almost always the engine light comes on going down the hill
4) If I just turn the key to start the engine again, it will run really rough
5) If I cycle the key to the full off position and then restart it, it runs FINE.
The engine codes that are recorded (which I will post later) are indicating that the computer "got an input from something that is telling it to shut down a couple of injector" - the reason for running rough.
Both local mechanics AND the Subaru dealer claim the "idle valve body is bad" (I'll get the details also later) - but the local mechanic replaced this $400 part with NO difference...
Seems like the lean condition down hill combined with the cold condition is causing the problem - NO ONE HAS BEEN ABLE TO reproduce the problem on flat ground on in town! The codes are not pointing to a problem...the the resulting condition.
Any ideas?
Mark
CountryBoy is offline   Reply With Quote
Old 03-29-2011, 12:45 AM   #2 (permalink)
Tuneup would be nice as well as mileage.
We REALLY need the codes to help otherwise I cab just toss out some guesses.
