Hood latch diagram /problem - Subaru Outback - Subaru Outback Forums
post #1 of 5 (permalink) Old 03-28-2006, 11:46 AM Thread Starter
Question Hood latch diagram /problem
Hello and sunny day from Big Sky country.
I have a problem with my hood latch release cable. I think it has come undone from the front latch. Meaning that I 'popped' the hood using the inside release....checked what I needed and now I can't get the hood to completely shut. It will latch on the front latch so it won't blow up in wind but I think the cable came undone. I have been very unsuccessful finding a diagram to be able to fix it.
I checked my repair manual last night and no diagram included for this area......HELP???? I thinks its pretty simple and worst case I start fiddling around but would love to have the diagram to not have to do that.
Arrrghh!
Thanks very much for your help/ideas if anyone has any. I have a 98 OB.
subnme is offline
post #2 of 5 (permalink) Old 03-28-2006, 12:08 PM
RCoaster's Avatar
Car: 2004 Subaru Outback 35th Anniversary Edition, H6 3.0 4EAT
Is it possible that the latch might have moved to the closed position? All you need to do is to reopen the hood latch via the release inside the car to pop it back open and then close the hood. The cable attachment is on the outside of the latch, as disassembly of the hood latch is not recommended due to the strong springs under tension inside. If it is only the cable, look for a small lever near the cable bracket and that is where the cable attaches to the latch release lever.
RCoaster is offline
post #3 of 5 (permalink) Old 03-29-2006, 05:19 PM Thread Starter
I apologize if I miss something here in my reply. I can't see the answer when I am replying so going off memory
The hood release inside the car just 'swings' back and forth . Not locked back into its place if you will. The cable at that inside lever still looks connected.
When I lift the hood and look down I can't see the cable or where it goes. I assume its the cable that sits right along the edge of the entire engine compartment and looks like it runs in front of the radiator ? The hood latch on the outside looks fine and it hooks the the front one so it will stay down just won't shut all the way.
I am missing something I am sure but I can't see where the cable hooks to anything as you mentioned. Should I have to take anything off /apart to see/fix what you were referring too??
Thanks for your patience.
subnme is offline
post #4 of 5 (permalink) Old 03-29-2006, 05:20 PM Thread Starter
*oh...scroll down a bit and I can see what you wrote as I reply..oops.
subnme is offline
post #5 of 5 (permalink) Old 03-30-2006, 09:32 AM
RCoaster's Avatar
Since the lever inside the car swings freely, the cable might have become disengaged or broke at the release lever. You'll have to get under the dash and find out if the cable has broken at that point. If the cable hasn't broken and is still attached to the release lever, then the release lever on the hood latch may have become stuck. Just go WD-40 crazy on the hood latch to lube it up and get it working freely again.
You can remove the latch assembly from it's bracket, but don't take apart the inner workings!
Hope this helps.
RCoaster is offline
