Hello all. First time poster, long time reader.
I'm from Canada, southern Saskatchewan (for Americans, this would be similar to Fargo ND). My Outback has 180,000 kms (115,000 miles), mostly highway. It's been *very* well maintained. Service manual has been fully respected and other than basic maintenance, no work has been required. I recently started to smell burning oil, and shortly after that noticing a couple drops of oil under the vehicle after it's been sitting for a few hours/overnight (note: the "diaper" is long gone, if that matters). My mechanic is telling me the head gasket has an external leak. I'm not mechanical at all, but I guess this means there's a crack? Regardless, engine has to come out and they're estimating $1,000 of labour, $1,000 parts (which includes remachining of something-or-other). In addition, the CV boots need work. They had identified this as a problem during my last oil change and advised that it was only worth monitoring for now and replacing once it cracked. So...now it's cracked. They're estimating $800 for this. Based on my very limited knowledge and recent interwebs research, I'm thinking this estimate must imply something to do with the axel...because the CV joints should have been addressed sooner? They are sending a complete estimate tomorrow, but called to 'spit ball' numbers because they weren't sure I'd want to keep the vehicle (note: this is an independent mechanic, not a dealer)....that struck me as odd. It'd be a no brainer to invest $3,000 in the vehicle, no? Otherwise, anything here strike you as odd? I've owned some *very* old vehicles in my lifetime...and have been very unkind to many of them. The CV joints is standard...the head gasket seems like an unusual failure for a newer vehicle that has been babied and mostly seen highway. Summarization: - Head gasket failure...should I be getting a second opinion? Does this failure seem odd? - CV joints - did mechanic screw up by not addressing this sooner and just "monitoring" for now? Does price seem right? - Car is worth the investment...right? - Should I take such a major repair to the dealer, for any particular reason? Thank you very much, in advance, if you managed to read all of that. Even greater thanks if you respond
Car: 2006 Outback XT Limited
Prices quoted seem a bit high for head gasket job and ridiculously high for cv work. I haven't tracked the CAD $ lately, and I don't know your local labor rates. Just shooting from the hip there.
Head gaskets are problematic on that engine. Subaru may help defray the cost- but that is usually only if you have one of their dealers do the work. And I don't know if that applies to Subaru of Canada. I'll let others jump in there. Good luck!
Wilwood Superlite front calipers DBA slotted Legacy GT front rotors w/Carbotech 1541 front pads; Hawk HPS rear pads and SS hoses all around Grimmspeed Master Cylinder Brace KYB GR-2 struts (2000-2004 version on rear) Rallitek sway bars F&R + AVO rear sway bar reinforcement brackets JDM divorced stereo/HVAC controller, JVC DD stereo No, I didn't rebuild my car overnight. Just testing a pimped out sig for a week or so... |
Labour charges out at $60 to $80 for a lot of independents. Dealers will sometimes charge out at $80 to $100. I think that's very comparable to American rates.
Parts can be considerably more expensive in Canada, with the variance being wildly different depending on whether it's after market, etc. Appreciate the quick feedback. |
#4 (permalink) | |
When a CV boot tears, all the grease comes out. You'll probably notice a blue-green spattering in the wheel wells. If you notice it quickly, you can get the CV boot repaired for cheap. It's just a rubber boot, fill it up with grease, good to go. If you DON'T notice it right away (or don't repair it right away), you're running your CV joint with no grease, and allowing dirt+water in there. It will wear out very quickly, and now you need a new CV joint (On a lot of cars, that's the entire half-axle - I'm not sure if that's true with Subaru or not). So $800 is not unreasonable, given the cost of parts+labor. |
#5 (permalink) | |
#6 (permalink) | |
The only way I can see it being worth it to repair a boot right away is if you have low mileage on the axles and know that they are in great condition. And even then, you can still 'monitor' and just replace it when it actually tears rather than replacing it before it fails. So long as you're actually monitoring it, of course - if you ignore it, you could miss the tear and end up going a long time with no grease and ruining it. Summary: At 120k, you were going to want to put in a new axle anyway, so the cost didn't change any by waiting. |
Regarding the CVs-
A worn boot is just that- worn. No worries yet. Once it's torn, you'll get accelerated wear from contamination as noted above. If yours can be rebooted & repacked with grease, that's great. Many can be, even with lots of miles on them. If not, you should insist on Subaru replacements. The aftermarkets nearly always leave you with an odd vibration at idle. They work great, last a long time and are generally cheaper... but they also come with that weird side effect. Your car has 8 CV joints. It would be unheard of for them to all fail at once- make sure the estimate you are getting is just for what has failed or is about to fail. I treat those parts as "replace as needed" rather than pre-emptively on a schedule. Some go the life of the car without attention. To answer one of your first questions, yes get a second opinion on the head gasket. It may ultimately be most useful to get that from a dealer, in the event that Subaru of Canada is making the sorts of accommodations that Subaru of America sometimes has done for those with HG trouble. |
#8 (permalink) |
Great forum, you guys have been a tremendous help. Thank you.
I talked to the dealer, and they said the HG problem was fixed for 2004 and subsequent models. For pre-2004 models Subaru Canada did make accomodations outside of the warranty as there was a known issue. Sound right? Any anecdotes regarding 'accomodations' Subaru USA has made, and how to access? Bypass the dealer? This has been, by far, the most enjoyable vehicle I've ever owned, however, this head gasket problem has me reconsidering whether I'd ever buy Subaru again. Seems unacceptable for a 2007 that's been pampered.....though, maybe the known HG problem is a red herring and my case is simply one of bad luck. Or maybe I just hate spending money :P |
#9 (permalink) | |
See also: Was the head gasket issue resolved with newer models? and I think last question on 2013 outback, head gasket issues I'm not aware of any "accommodation" made by SCI. I've asked mechanics and sales people at dealerships about this in the past. This doesn't mean it hasn't occurred, as it's possible the deal involves a non-disclosure agreement. There were earlier engines that developed piston slap, and I was told that SCI helped with that. As for SOA, there's lots of posts here where U.S. owners have approached the company and been offered some degree of assistance, usually reported to also require the work is done at a Subaru dealer. |
#10 (permalink) |
Those links and your post raise a question I hadn't really considered...if there is a 2007 HG issue, they'd only start surfacing now. I put a lot of KMS on my car, so I'd be near the front of the pack.
